My Oil Analysis Results!Anyone use a "FilterMag" magnet #534244
11/23/09 09:41 AM
11/23/09 09:41 AM
United States
STLDuster Offline OP
United States
I have about 10,000 miles on my '09 Ram. When I switched to mobil 1 a while back I noticed some valve train noise upon start up. After doing some homework on the issue, I found that some other people had similiar issues. Not just with the Mopar engines, it was hit or miss across the board.
So I couldnt stand it any longer and changed my oil at 4500 miles. I collected a sample of it and sent it in to be tested. I wanted to see what was going on in my new engine.
Here are the results;
I was so relieved! Wix Filters Rock!
I am tempted to pick up a filter magnet and stick on the filter to help removed what iron is being passed through.
Does anyone have any experience with them? I am looking at this one:
http://www.jegs.com/i/FilterMAG/384/HP365/10002/-1
"No great genius has ever existed without some touch of madness." - Aristotle
Re: My Oil Analysis Results!Anyone use a "FilterMag" ma [Re: STLDuster] #534245
11/23/09 02:49 PM
11/23/09 02:49 PM
MoreParts Offline
MoreParts  Offline
I use both a filter and an oil plug magnet. I've never really checked on the filter magnet, but the oil plug magnet always picks up metal that I can see during my oil changes.
Re: My Oil Analysis Results!Anyone use a "FilterMag" ma [Re: MoreParts] #534246
11/23/09 03:12 PM
11/23/09 03:12 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I run one on my daily driver. I have cut the filter open a few times and it will always have a small collection of iron particles where the magnet sat. Not a lot, but enough to see that it's doing something.
I also run a napa gold filter, which is made by wix.
Re: My Oil Analysis Results!Anyone use a "FilterMag" ma [Re: MoreParts] #534247
11/23/09 03:12 PM
11/23/09 03:12 PM
Costa Mesa, CA
chache876 Offline
chache876  Offline
Costa Mesa, CA
wouldn't a magnet on the filter possibly cause it to clog?
I would at least get a magnetic drain plug
Re: My Oil Analysis Results!Anyone use a "FilterMag" ma [Re: chache876] #534248
11/23/09 03:15 PM
11/23/09 03:15 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
If the magnet is collecting enough metal to physically clog the oil filter the engine would be junk at that point.
Re: My Oil Analysis Results!Anyone use a "FilterMag" ma [Re: Neil] #534249
11/23/09 03:22 PM
11/23/09 03:22 PM
Costa Mesa, CA
chache876 Offline
chache876  Offline
Costa Mesa, CA
Good point. Although $70 is kinda steep for a magnet. I wonder if you could find something locally for cheaper
Re: My Oil Analysis Results!Anyone use a "FilterMag" ma [Re: chache876] #534250
11/23/09 09:18 PM
11/23/09 09:18 PM
Maryland
GO_Fish Offline
GO_Fish  Offline
Maryland
I've had this discussion with a great mechanic with 40+ years experience. He feels that pressure and flow are too great inside the oil filter for a weak magnet to have full effect. I run a magnetic drain plug on all my cars. Inside the trans pan I have a strong "earth" magnet on my old HP cars (newer stuff already has a magnet in the pan), and on the outside of the oil pan on the engine. Oil will make its way down to the pan and get pulled to the magnet, even when the vehicle is not running.
Scott B. "I'm a self-made man... I started with nothing, and I still have most of it!" 68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph 69 340 GTS stock 14.18@ 95.60 mph 01 5.9L Ram 1500 Quad Cab 4x4 01 3.5L 300M 16.23@ 86.97 mph
Re: My Oil Analysis Results!Anyone use a "FilterMag" magnet [Re: STLDuster] #534251
11/24/09 11:08 AM
11/24/09 11:08 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
the majority of the circulating grit in the oil is usually not metallic ... unless the equipment is at a steel mill or taconite mine
nothing wrong with a magnet,
it just does not produce 'miracles'
Re: My Oil Analysis Results!Anyone use a "FilterMag" magnet [Re: 360view] #534252
11/24/09 11:22 AM
11/24/09 11:22 AM
nothing wrong with a magnet, it just does not produce 'miracles'
I agree and alot of the metallic debris isn't even ferrous but I would use a powerful one made for this that goes around the outside of the filter (not a deal breaker but it helps me sleep better at night )
Re: My Oil Analysis Results!Anyone use a "FilterMag" magnet [Re: RapidRobert] #534253
11/24/09 12:06 PM
11/24/09 12:06 PM
Wilmington,NC
I
I go fast Offline
I go fast  Offline
I
Wilmington,NC
And if the metal gets to the filter,just how would it go any farther.
Re: My Oil Analysis Results!Anyone use a "FilterMag" magnet [Re: I go fast] #534254
11/24/09 12:27 PM
11/24/09 12:27 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I have a large magnet I use during cam break in that covers teh end of the filter... But I dont place a ton of faith in it... just something that sounded like a good idea. And it doesnt get used during any other time...lol.
Re: My Oil Analysis Results!Anyone use a "FilterMag" magnet [Re: moper] #534255
11/24/09 03:13 PM
11/24/09 03:13 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Could always put a couple hard drive magnets on the bottom of the oil pan. Those magnets are pretty tough and after you key off they would definitely collect any shavings suspended in the oil.
