what's the best nitrous progressive controller
#533856
11/22/09 09:35 PM
11/22/09 09:35 PM
Posts: 345 iowa
wesw
iowa
what nitrous progressive controller should i use for my new engine? it's a 588ci predator with two stages on it. i've never used it before. it's all new to me. thanks guys
598 ci predator
Re: what's the best nitrous progressive controller
[Re: cold85]
#533860
11/24/09 09:45 PM
11/24/09 09:45 PM
Posts: 672 Keysville, VA
drag440
mopar addict
mopar addict
Keysville, VA
Eddy can only run 1 stage and is very sensitive. Nos can control 2 and seems to be easy to use and easy to keep files and just upload different setups.
The NOS launcher is the best controller, but high dollar. It depends on what all you want it to do and your budget. I recomend the Eddy for first timers because its simple. It will cut on a second stage, but will only do the first in progession. I don't like multi stages myself. I like to keep it simple and use one big hit and ramp it in. I leave with 30% and ramp it all in by the 60' while the suspension is still loaded.
[Re: drag440]
#533861
11/25/09 01:17 PM
11/25/09 01:17 PM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Not entirely correct, the base "Launcher" costs around $400, same as an Edelbrock, but the NOS will control 2 kits, where as the Edelbrock controls 1. If you get the touch screen and some of the other goodies, the NOS can get expensive, but those are not required. The best bang for the buck, is the NOS "mini". same electronics as the "Launcher" just not as many things you can do with it, but it is a "straight line" progressive, same as the Edelbrock, plus it also controls 2 kits and only costs about $250.
Monte
[Re: Monte_Smith]
#533863
11/25/09 09:45 PM
11/25/09 09:45 PM
drag440
mopar addict
mopar addict
Keysville, VA
Monte
I did not know you could get a base Launcher. I have never seen them advertised, just the whole deal for like $750.00.
