what's the best nitrous progressive controller #533856
11/22/09 09:35 PM
11/22/09 09:35 PM
iowa
wesw Offline OP
wesw  Offline OP
iowa
what nitrous progressive controller should i use for my new engine? it's a 588ci predator with two stages on it. i've never used it before. it's all new to me. thanks guys
598 ci predator
Re: what's the best nitrous progressive controller [Re: wesw] #533857
11/22/09 10:59 PM
11/22/09 10:59 PM
Lehigh Acres, Florida
rickstershemi Offline
NOS or FJO mini controller will handle your needs ck the instructions at either site....FJO will let you download the software to evaluate....not sure about the NOS unit...????
Happen to have a very slightly used FJO unit I could be talked out of since I sold the 04 Truck.
Rickster
Re: what's the best nitrous progressive controller [Re: wesw] #533858
11/24/09 07:47 PM
11/24/09 07:47 PM
Keysville, VA
drag440 Offline
mopar addict
drag440  Offline
mopar addict
Keysville, VA
I'm using the Edelbrock one and love it. So simple a cave man can do it. Just be careful when you run your pos. and neg. wires. They need to be big enough and don't run them with any other wires and run them straight to the battery.
Re: what's the best nitrous progressive controller [Re: drag440] #533859
11/24/09 08:08 PM
11/24/09 08:08 PM
nc
cold85 Offline
cold85  Offline
nc
Eddy can only run 1 stage and is very sensitive. Nos can control 2 and seems to be easy to use and easy to keep files and just upload different setups.
Re: what's the best nitrous progressive controller [Re: cold85] #533860
11/24/09 09:45 PM
11/24/09 09:45 PM
Keysville, VA
drag440 Offline
mopar addict
drag440  Offline
mopar addict
Keysville, VA
The NOS launcher is the best controller, but high dollar. It depends on what all you want it to do and your budget. I recomend the Eddy for first timers because its simple. It will cut on a second stage, but will only do the first in progession. I don't like multi stages myself. I like to keep it simple and use one big hit and ramp it in. I leave with 30% and ramp it all in by the 60' while the suspension is still loaded.
Re: what's the best nitrous progressive controller [Re: drag440] #533861
11/25/09 01:17 PM
11/25/09 01:17 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Not entirely correct, the base "Launcher" costs around $400, same as an Edelbrock, but the NOS will control 2 kits, where as the Edelbrock controls 1. If you get the touch screen and some of the other goodies, the NOS can get expensive, but those are not required. The best bang for the buck, is the NOS "mini". same electronics as the "Launcher" just not as many things you can do with it, but it is a "straight line" progressive, same as the Edelbrock, plus it also controls 2 kits and only costs about $250.
Monte
Re: what's the best nitrous progressive controller [Re: Monte_Smith] #533862
11/25/09 02:55 PM
11/25/09 02:55 PM
O'Fallon,IL.
70RTRacer Offline
70RTRacer  Offline
O'Fallon,IL.
Good to see you getting it going Wes.
Re: what's the best nitrous progressive controller [Re: Monte_Smith] #533863
11/25/09 09:45 PM
11/25/09 09:45 PM
Keysville, VA
drag440 Offline
mopar addict
drag440  Offline
mopar addict
Keysville, VA
Monte
I did not know you could get a base Launcher. I have never seen them advertised, just the whole deal for like $750.00.
Re: what's the best nitrous progressive controller [Re: drag440] #533864
11/25/09 11:22 PM
11/25/09 11:22 PM
Here's a software screen shot of the FJO Minicontroller I have, very user friendly and you can save your setups.
Rickster
