1940 Plymouth Coupe
#528862
11/17/09 11:26 AM
11/17/09 11:26 AM
Does anyone know if the K-member from a 79 Aspen will fit into the 1940 Plymouthe coupe? Looks like it might be to long.
Re: 1940 Plymouth Coupe
[Re: poorboy]
#528865
11/17/09 11:15 PM
11/17/09 11:15 PM
Thanks for the info Poorboy do you know what year for the Dakota? I want to be able to run a 360 and automatic transmission.
#528867
11/19/09 09:07 PM
11/19/09 09:07 PM
Posts: 10,842 Freeport IL USA
poorboy
Freeport IL USA
The pre 91 Dakotas have the 5 on 4 1/2 bolt pattern wheels, the 91-95 (or 96) have the 6 bolt wheels, but you can swap out the rotors to convert to the 5 bolt wheels, newer then 95 (or 96) also have the 6 bolt wheels, but changing over to the 5 bolt requires more things to be changed. Any of the Dakota frames will work, but if you use the entire Dakota frame, most have to be adjusted for length. You can mount a 360 & auto (or most big blocks, check the truck section of Moparts for more info) on any Dakota frame, and other then length, you can pretty much use the Dakota frame as removed from under the truck.
There are 3 different wheel base length of Dakots frames, standard cab, short box, standard cab 8' box and extended cab short box, not sure what length frame they put under the newer quad cab trucks. Clips and frames from Dakota's have been covered here before, look around. Gene
[Re: poorboy]
#528868
11/21/09 01:07 AM
11/21/09 01:07 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
2000 and newer dakotas are not A arm /coil front end, they are strut,,maybe be as early as 1999 some where in that area,,so the earlier the better,, if you search your local craigs list i have sen people with broken down dakotas wanting to see cheaper then looking for a beater running truck,,,ive read some un believable low prices at you pull it yards for frames or front clips,, but i have never seen a dakota in a yard in my area,,,
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
#528869
11/21/09 01:12 AM
11/21/09 01:12 AM
fstfish66
levittown pa
i dont know how to post multipul pics at one time,,here are a few of a volare/aspen/mirada front end under a 48 dodge,,this project car was aquired wit hthis already mounted in place
[Re: fstfish66]
#528871
11/21/09 01:25 AM
11/21/09 01:25 AM
fstfish66
levittown pa
best front pic i have see the radiator mount posts,
[Re: fstfish66]
#528872
11/22/09 11:35 PM
11/22/09 11:35 PM
Posts: 56 orangeville,PA
plmczy
orangeville,PA
Fstfish, my 2000 Dakota has coil/a arm set up. I had to cut the nut off the bottom a arm for the shock mount because the bolt snapped off, what a pain,lol. Check your local u pull it's alot of the cash for clunker cars are showing up. I seen a couple older Dak's at Harry's in Hazelton this past saturday. later shawn
