NEW SUPER STOCK SPRINGS....PINION ANGLE? #526228
11/14/09 09:59 PM
11/14/09 09:59 PM
central ohio
mopar rookie Offline OP
central ohio
I just installed new super stock springs and hangers in my 64 plymouth. I installed the springs in the top hole of the front hangers as Mancini said it was the preferred position. It seems to me there is alot of pinion angle. Should I put the springs in the bottom hole to help this or is this normal. It is the same rear that was in the car when I got it, a 65-68 b body rearend.
Re: NEW SUPER STOCK SPRINGS....PINION ANGLE? [Re: mopar rookie] #526229
11/15/09 12:15 AM
11/15/09 12:15 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
If you install the springs in the top eye hole, you must shim the pinion back down to where it was before.
Re: NEW SUPER STOCK SPRINGS....PINION ANGLE? [Re: mopar rookie] #526230
11/15/09 01:42 AM
11/15/09 01:42 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Use the different bolt holes for the front of the springs to set the ride height.
Then, use the "search" feature to view the 4,639 posts/theories/guesses/hunches on setting pinion angle.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: NEW SUPER STOCK SPRINGS....PINION ANGLE? [Re: mopar rookie] #526231
11/15/09 09:10 AM
11/15/09 09:10 AM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
it looks like you have about 8/10* up
start thinking about having the perches rewelded.get an angle finder and check it.what part # are those?
Re: NEW SUPER STOCK SPRINGS....PINION ANGLE? [Re: blownzoom440] #526232
11/15/09 09:22 AM
11/15/09 09:22 AM
Canada
Dons Dart Offline
Dons Dart  Offline
Canada
Yep you will have to reweld your spring pearches.If the angle was way down then you could slide wedges under your spring perches to get it were you want to be.been there done that.
Re: NEW SUPER STOCK SPRINGS....PINION ANGLE? [Re: Dons Dart] #526233
11/15/09 10:54 AM
11/15/09 10:54 AM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
??? The wedges can be installed in either direction.
Rewelding the perches is the better way to do it. I've also made custom steel wedges and welded them to the perches.
Re: NEW SUPER STOCK SPRINGS....PINION ANGLE? [Re: Evil Spirit] #526234
11/15/09 11:52 AM
11/15/09 11:52 AM
central ohio
central ohio
If I put the springs in the bottom hole that will take care of some of the angle? I put the tires on it just to see where the ride hieght was and it isnt as high as I thought it was going to be, so I am going to move them to the lower hole and see where that gets me. Not sure of the part whole part number on the springs but one ends in 56 and the other 57. If I do have to change it I hope I can just shim it cause the rear is powder coated and don't want to weld on it
Re: NEW SUPER STOCK SPRINGS....PINION ANGLE? [Re: mopar rookie] #526235
11/15/09 12:02 PM
11/15/09 12:02 PM
ELYRIA,OH
ELYRIA,OH
find the angle though so you know what you have.
what is the rear hanger angle?
Re: NEW SUPER STOCK SPRINGS....PINION ANGLE? [Re: blownzoom440] #526236
11/15/09 01:33 PM
11/15/09 01:33 PM
Ohio
V
viperakron Offline
viperakron  Offline
V
Ohio
I just installed SS springs in my 64 B Body. I just tacked the pads in case I need to move it. But the right side of the car really sitting up. I hope when I put the torsion bars back in it will transfer some wieght and even things out.
