50 Dodge Gasser-How high w/ front coils? #525094
11/13/09 05:22 PM
11/13/09 05:22 PM
Cottage Grove OR
WFO Offline OP
WFO  Offline OP
Cottage Grove OR
Hey Rodders-
I'm looking into buying this 50 Dodge Business Coupe:
http://portland.craigslist.org/mlt/cto/1457217373.html
I want to build a gasser style street car with the 383 6bbl and 727 out of my '65 Fury.
In looking around I've dicovered that the original "High and Mighty" gasser was a modified stock front end.
My question is if anyone has any idea how high up I can go with a larger front coil spring,maybe a set of big block moroso trick springs of the proper diameter?
I've read that the Chrysler engineers that built high and mighty used spacers,anyone seen these?I don't need to go as high as those guys did,so it may not be necessary...
Also,any general opinions on this car/build are welcome.
Thanks,Sean
'65 Plymouth Sport Fury
Blow thru twin turbo coming soon...
Re: 50 Dodge Gasser-How high w/ front coils? [Re: WFO] #525095
11/14/09 02:12 AM
11/14/09 02:12 AM
S.E. South Dakota !
bigdad Online content
Still Posting A Lot
bigdad  Online Content
Still Posting A Lot
S.E. South Dakota !
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 50 Dodge Gasser-How high w/ front coils? [Re: bigdad] #525096
11/14/09 11:23 AM
11/14/09 11:23 AM
SE Wisconsin
49wayfarer Offline
49wayfarer  Offline
SE Wisconsin
After seeing the build in street rodder mag, I wished I did mine as a gasser.
Re: 50 Dodge Gasser-How high w/ front coils? [Re: 49wayfarer] #525097
11/14/09 02:52 PM
11/14/09 02:52 PM
Cottage Grove OR
WFO Offline OP
WFO  Offline OP
Cottage Grove OR
Yeah my Dad brought me over those Street Rodder mags.They did a pretty good job with theirs so far.
I like how they radiused their wheelwells,that's something I think I'd definitely do.
I was thinking a set of 3200# super stock leaf springs might be a cheap way to get the rear end up to speed . Prolly go with an 8.75 rear.
The thing about the front end is if you HAVE to chop it off and go with a solid and leafs,fine.If that's just something guys do because that's what everybody does,I'm gonna need a better reason than that..
Re: 50 Dodge Gasser-How high w/ front coils? [Re: WFO] #525098
11/15/09 12:52 AM
11/15/09 12:52 AM
St. Louis, MO
Blues_Cuda Offline
Blues_Cuda  Offline
St. Louis, MO
Not sure what year this one is...I see it at a lot of local shows though.
Re: 50 Dodge Gasser-How high w/ front coils? [Re: Blues_Cuda] #525099
11/15/09 02:23 PM
11/15/09 02:23 PM
Pa. bucks county
cuhemida Offline
cuhemida  Offline
Pa. bucks county
from looking at the grille its a 1949 dodge coupe
Re: 50 Dodge Gasser-How high w/ front coils? [Re: WFO] #525100
11/16/09 01:23 AM
11/16/09 01:23 AM
levittown pa
fstfish66 Offline
fstfish66  Offline
levittown pa
3 windows are hard as heck to find,,some one needs to do some thing with this,,hopefully it will end up mopar powered,,
1966 barracuda prostreeter super charged 340(SOLD)
1940 dodge coupe 241 hemi street rod
2014 ram express hemi 4x4 dailey driver
2015 cherokee
2013 R/T classic
