Hey Rodders-
I'm looking into buying this 50 Dodge Business Coupe:
http://portland.craigslist.org/mlt/cto/1457217373.htmlI want to build a gasser style street car with the 383 6bbl and 727 out of my '65 Fury.
In looking around I've dicovered that the original "High and Mighty" gasser was a modified stock front end.
My question is if anyone has any idea how high up I can go with a larger front coil spring,maybe a set of big block moroso trick springs of the proper diameter?
I've read that the Chrysler engineers that built high and mighty used spacers,anyone seen these?I don't need to go as high as those guys did,so it may not be necessary...
Also,any general opinions on this car/build are welcome.
Thanks,Sean
