I'm running a 318 stroker with Eddy heads. K1 4" crank (makes 390cid), Eagle rods, Ross pistons, out of the box Eddy's, HS rockers, Comp cam .540/.555 252/262 @.050, Air Gap Intake, 750 gas carb.
I mainly built it because I picked up the pistons really cheap and you can find 318s all day long.
With TTI headers, full exhaust and quiet mufflers, 3.91 gear posi in 8 3/4, 26x10 slicks, 727 with 9.5" Dynamic converter, full interior, stock gas tank completely full to help push the fuel to the mechanical fuel pump. I think the car weighs 3,300lbs, can remember but we weighed in early spring.
It ran a new best this past weekend, 11.35 at 117mph and on the brakes (still broke out...) Shifting at 5,700rpm.
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
