Because the 318 blocks are so plentiful just grab a standard bore block with caps that looks good, with minimum ridge and sonic that.Limit your overbore to 30 thou to keep the walls as thick as possible.318's are at no disadvantage in wall thickness compared to the other displacements in the family.
