fine. flow will be _slightly_ decreased over a larger bore due to slightly more shrouding. would be more pronounced the bigger the valve (say, a 2.08 over a mag sized 1.92 or 2.02)
IMHO the only reason to do a 318 stroker is to use a pretty common '85-91 318 roller cam block, and use a hydraulic roller cam and stock roller lifters. otherwise, you're just giving up 18-34 cubes.
1976 Spinnaker White Plymouth Duster, /6 A833OD 1986 Silver/Twilight Blue Chrysler 5th Ave HotRod **SOLD!*** 2011 Toxic Orange Dodge Charger R/T 2017 Grand Cherokee Overland 2014 Jeep Cherokee Latitude (holy crap, my daughter is driving)
