Re: BENCH RACING: 8-71 V.S. Procharger?
[Re: bigtimeauto]
#518079
11/09/09 06:21 PM
11/09/09 06:21 PM
Posts: 8,647 ELYRIA,OH
blownzoom440
ELYRIA,OH
I only run 18* or 24* max if i want to get after it. whats up with that 34*?
i lost too much HP with less.
[Re: ZIPPY]
#518082
11/09/09 06:33 PM
11/09/09 06:33 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
i would have to believe the e85 will be better than pump gas
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: blownzoom440]
#518083
11/09/09 06:34 PM
11/09/09 06:34 PM
Posts: 1,771 St.Clair Shores MI.
tilt
St.Clair Shores MI.
What is your initial * and how much do you pull out per pound of boost?
68 CORONET R/T BEST MACHINE BUILT EFI'd TWIN TURBO(UP and RUNNING !!)
03 Mach1
[Re: bigtimeauto]
#518085
11/09/09 06:36 PM
11/09/09 06:36 PM
Posts: 202 CA
62SAVOY
CA
Here is what my instructions say that came with it:
Timing: Mechanical advance distributor recommended! 16-22 degrees initial crank timing with total of 32-36 degrees all in by 2500 rpm. These timing recommendations are suggested for a low compression, street driven engine running on premium, 92 octane, leaded or unleaded pump gas.
[Re: 62SAVOY]
#518089
11/09/09 06:51 PM
11/09/09 06:51 PM
Posts: 833 MN
hemidup
MN
My lastest and best 11.08 pass was with 18*s of timing at wot. No intercooler or aftercooler, just using W/M for now. I'd like to bump the timing to 21*s and put this fat azz truck of mine into the 10's.
Jerry Williams.
[Re: bigtimeauto]
#518090
11/09/09 06:53 PM
11/09/09 06:53 PM
tilt
St.Clair Shores MI.
Pulling the power back in essence with digital box for traction.
03 Mach1
[Re: tilt]
#518095
11/09/09 07:14 PM
11/09/09 07:14 PM
bigtimeauto
Trophy Winner
Trophy Winner
cool,that and a boost controller and your good. unless thats built in also
[Re: bigtimeauto]
#518096
11/09/09 07:17 PM
11/09/09 07:17 PM
tilt
St.Clair Shores MI.
It has that capability just need the solinoids from a Gran National or turbo T/A.
03 Mach1
