Page 4 of 5 1 2 3 4 5
Re: BENCH RACING: 8-71 V.S. Procharger? [Re: bigtimeauto] #518079
11/09/09 06:21 PM
11/09/09 06:21 PM
ELYRIA,OH
blownzoom440 Offline
ELYRIA,OH
I only run 18* or 24* max if i want to get after it. whats up with that 34*?
i lost too much HP with less.
Re: BENCH RACING: 8-71 V.S. Procharger? [Re: bigtimeauto] #518080
11/09/09 06:27 PM
11/09/09 06:27 PM
St.Clair Shores MI.
tilt Offline
tilt  Offline
St.Clair Shores MI.
68 CORONET R/T BEST MACHINE BUILT EFI'd TWIN TURBO(UP and RUNNING !!) 03 Mach1
Re: BENCH RACING: 8-71 V.S. Procharger? [Re: blownzoom440] #518081
11/09/09 06:28 PM
11/09/09 06:28 PM
S.E. Michigan
ZIPPY Online content
ZIPPY  Online Content
S.E. Michigan
Roots on e85, anyone?
The ethanol noticeably cools the intake charge, at least my buddys roots case "feels" considerably cooler to the touch...I can't seem to find anyone who knows exactly what the difference is in charge cooling between gas and e85.
Re: BENCH RACING: 8-71 V.S. Procharger? [Re: ZIPPY] #518082
11/09/09 06:33 PM
11/09/09 06:33 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
i would have to believe the e85 will be better than pump gas
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: BENCH RACING: 8-71 V.S. Procharger? [Re: blownzoom440] #518083
11/09/09 06:34 PM
11/09/09 06:34 PM
St.Clair Shores MI.
tilt Offline
tilt  Offline
St.Clair Shores MI.
What is your initial * and how much do you pull out per pound of boost?
Re: BENCH RACING: 8-71 V.S. Procharger? [Re: tilt] #518084
11/09/09 06:35 PM
11/09/09 06:35 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
me? 36* digital 7
Re: BENCH RACING: 8-71 V.S. Procharger? [Re: bigtimeauto] #518085
11/09/09 06:36 PM
11/09/09 06:36 PM
CA
62SAVOY Offline
62SAVOY  Offline
CA
Here is what my instructions say that came with it:
Timing: Mechanical advance distributor recommended! 16-22 degrees initial crank timing with total of 32-36 degrees all in by 2500 rpm. These timing recommendations are suggested for a low compression, street driven engine running on premium, 92 octane, leaded or unleaded pump gas.
Re: BENCH RACING: 8-71 V.S. Procharger? [Re: 62SAVOY] #518086
11/09/09 06:39 PM
11/09/09 06:39 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
with boost?
Re: BENCH RACING: 8-71 V.S. Procharger? [Re: bigtimeauto] #518087
11/09/09 06:41 PM
11/09/09 06:41 PM
St.Clair Shores MI.
tilt Offline
tilt  Offline
St.Clair Shores MI.
me? 36* digital 7
No.. metal storm, just curious is all.
I run 38* initial and have the BS3 pull back to 20* at 15 psi under load.
Re: BENCH RACING: 8-71 V.S. Procharger? [Re: tilt] #518088
11/09/09 06:50 PM
11/09/09 06:50 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
me? 36* digital 7
thats ok formaking power but for drag racing you need more flexability ie,starting line retard
Re: BENCH RACING: 8-71 V.S. Procharger? [Re: 62SAVOY] #518089
11/09/09 06:51 PM
11/09/09 06:51 PM
MN
hemidup Offline
hemidup  Offline
MN
My lastest and best 11.08 pass was with 18*s of timing at wot. No intercooler or aftercooler, just using W/M for now. I'd like to bump the timing to 21*s and put this fat azz truck of mine into the 10's.
Jerry Williams.
Re: BENCH RACING: 8-71 V.S. Procharger? [Re: bigtimeauto] #518090
11/09/09 06:53 PM
11/09/09 06:53 PM
St.Clair Shores MI.
tilt Offline
tilt  Offline
St.Clair Shores MI.
Pulling the power back in essence with digital box for traction.
Re: BENCH RACING: 8-71 V.S. Procharger? [Re: tilt] #518091
11/09/09 06:56 PM
11/09/09 06:56 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
correct, i leave on 4* and ramp to the 18* in 2.5 sec.true 10.5 tire
Re: BENCH RACING: 8-71 V.S. Procharger? [Re: bigtimeauto] #518092
11/09/09 07:00 PM
11/09/09 07:00 PM
St.Clair Shores MI.
tilt Offline
tilt  Offline
St.Clair Shores MI.
Hang on for the ride after the 2 sec mark.
Re: BENCH RACING: 8-71 V.S. Procharger? [Re: tilt] #518093
11/09/09 07:03 PM
11/09/09 07:03 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
been 174 so far
Re: BENCH RACING: 8-71 V.S. Procharger? [Re: bigtimeauto] #518094
11/09/09 07:10 PM
11/09/09 07:10 PM
St.Clair Shores MI.
tilt Offline
tilt  Offline
St.Clair Shores MI.
been 174 so far
Ya Daddy !
Not to highjack the thread but it looks like the FI system i have can do the timing pullback.
Re: BENCH RACING: 8-71 V.S. Procharger? [Re: tilt] #518095
11/09/09 07:14 PM
11/09/09 07:14 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
cool,that and a boost controller and your good. unless thats built in also
Re: BENCH RACING: 8-71 V.S. Procharger? [Re: bigtimeauto] #518096
11/09/09 07:17 PM
11/09/09 07:17 PM
St.Clair Shores MI.
tilt Offline
tilt  Offline
St.Clair Shores MI.
It has that capability just need the solinoids from a Gran National or turbo T/A.
Re: BENCH RACING: 8-71 V.S. Procharger? [Re: tilt] #518097
11/09/09 07:27 PM
11/09/09 07:27 PM
ELYRIA,OH
ELYRIA,OH
i used 16 at idle and 34*in at 2K,no boost retard.i put a roller in it and dyno'd it[video in sig]but with only 30* locked.no problems starting at all.7AL-2.i had 10%OD on the blower.with bigger carbs now i run 10%UD and went 3mph faster,.25 quicker.
Re: BENCH RACING: 8-71 V.S. Procharger? [Re: blownzoom440] #518098
11/09/09 07:32 PM
11/09/09 07:32 PM
St.Clair Shores MI.
tilt Offline
tilt  Offline
St.Clair Shores MI.
Have you tried a BTM box??
Just curious to see if it picks up even more.
