Page 3 of 3 1 2 3
Re: mopar smallblock .474 cam [Re: Challenger 1] #516963
11/09/09 10:10 PM
11/09/09 10:10 PM
Ontario.Canada
can.al Offline OP
can.al  Offline OP
Ontario.Canada
...if you light the fire a little earlier it will have a more time to complete burning prior to exhaust.
maybe a little less raw gas burning and popping in the pipes.......but wait,we like that don't we? ...al
Re: mopar smallblock .474 cam [Re: can.al] #516964
11/10/09 12:28 AM
11/10/09 12:28 AM
La Verne, CA
lakerism Offline
lakerism  Offline
La Verne, CA
How would an LD340 intake work with this cam?
Re: mopar smallblock .474 cam [Re: lakerism] #516965
11/10/09 12:31 AM
11/10/09 12:31 AM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
Very well matched combo.
Re: mopar smallblock .474 cam [Re: can.al] #516966
11/10/09 12:32 AM
11/10/09 12:32 AM
Detroit, USA.
MagnumGT Offline
MagnumGT  Offline
Detroit, USA.
I have noticed a serious downward slide of the quality of our gasoline which you may or may not have to deal with "up there"...you using pump gas? If so, it just don't wanna burn! My last van - 360/TQ/'79 case in point. Took a carb from my 440, it was not rich enough. Jetted it once and even had to go to smaller rods after that, it finally ran after 3 changes. Only explanation= it's about 80% actual fuel and the rest is some recipie if you ask me. No way that carb was too lean for a stock 360.
Re: mopar smallblock .474 cam [Re: can.al] #516967
11/12/09 07:22 PM
11/12/09 07:22 PM
La Verne, CA
lakerism Offline
lakerism  Offline
La Verne, CA
What do you guys think would be the best head choice for this cam plus an LD340 intake? 'X' heads? 'J' heads? Eddy RPM aluminums? Would aDemon 750 carb be too much? Thanks!
Re: mopar smallblock .474 cam [Re: lakerism] #516968
11/19/09 02:33 PM
11/19/09 02:33 PM
Canada
Dons Dart Offline
Dons Dart  Offline
Canada
Ok for the purple cam what about springs,retainers and keepers what is recomended,I have 901 comp springs and retainers in my 318 heades can i use them in my 340 j heads.
Page 3 of 3 1 2 3
