Re: mopar smallblock .474 cam
[Re: 383man]
#516927
11/06/09 01:55 AM
11/06/09 01:55 AM
Posts: 6,098 Valencia, España
NachoRT74
Valencia, España
here is when I get some questions. For same cam I got divided opinions to a 400, taking in mind I will raise compression with pistons, but then it looks good mounted on a SB, with less displacement and stroke, and no more engine build specs posted
I simply don't get it.
[Re: NachoRT74]
#516928
11/06/09 03:51 AM
11/06/09 03:51 AM
dulcich
I ran that cam in a couple of 340's back in the day. 340 4spd 'cuda, pulled the revs to 6500 and 12's through the lights. Lot's of chop at idle. Loved that hemigrind.
Ran one in a 340 in a 4x4 W150 in the mid '80s, all the usual mods (LD340 Headers, 440AVS, good X heads etc) , was faster than the basically stock 440 (HP manifolds, TRW's, Torker, 750 Holley, factory HP cam) that came after the 340 broke the steel crank. Strong midrange torque in the truck, choppy idle, low vacuum. It was a mean cam.
[Re: can.al]
#516935
11/06/09 04:12 PM
11/06/09 04:12 PM
Posts: 535 Ohio
racerAL
Ohio
great little cam...pulls hard and sounds really good with the right mufflers.i've ran it in multiple mild 340 builds and it has never disapointed me...i've sold quite a few of them over the years..MP P4452992 $180
-1967 Plymouth Satellite #3555 446 cid on E-85 best 1/4 et 10.577 @ 127.58 best 1/8 et 6.722 @ 100.68 best 60ft. 1.419
[Re: Dons Dart]
#516937
11/06/09 04:23 PM
11/06/09 04:23 PM
Challenger 1
Cincinnati, Ohio
This is great feed back on that cam,I am planning on pulling my comp cam out soon and that is the cam i was thinking of.I can get it here at my local Mopar dealer for 198 bucks includs lifters.One Question did any of you have to change to different pushrods or go with adjustable rockers I want to double check because so many of you have run this cam.So can it be installed useing stock pushrods and stock rockers.Thanks Dons Dart.
I ordered new Smith Bros push rods and used adj rockers.
[Re: Dons Dart]
#516938
11/06/09 04:23 PM
11/06/09 04:23 PM
Posts: 535 Ohio
racerAL
Ohio
racerAL could you answer my question please or someone else.
...sorry Don...yea,you can run stock(hyd)pushrods and rockers.
