Re: Any "Baby Hemi" powered hot rods out there?
[Re: Ply36]
#51646
01/17/10 03:40 AM
01/17/10 03:40 AM
Posts: 1,757 levittown pa
fstfish66
levittown pa
PLY36 FEEL FREE TO E MAIL THEM TO ME,,and remind me to resize them then ill post them,, lets see a pic of the car,,,,what dizzy you running/??? and how do you like the 3 carbs ??? 2 bbls ide assume? fstfish66@aol.com
1966 barracuda prostreeter super charged 340(SOLD) 1940 dodge coupe 241 hemi street rod 2014 ram express hemi 4x4 dailey driver 2015 cherokee 2013 R/T classic
[Re: fstfish66]
#51647
01/17/10 12:17 PM
01/17/10 12:17 PM
Posts: 296 Michigan
Ply36
I'm running a Mallory. I initially tried a MSD, but the intake manifold extended back too far to slide the distributor in. With smaller diameter, the Mallory makes it in, but not by a whole lot. I'm happy with the tri-power set up. One aspect of it is the visual, it just looks cool on a Hemi. Performance-wise, it's better when I nail it in first (rolling) or from a stop, but if I open all six at about 70 or so, it's less impressive. Just an adjustment issue, I haven't hit the right combination yet. The carbs are Rochester, they're all functional. As a lot of you already know from your own experience, the real fun is in the driving. It's never been on a dyno, but the best guess is I'm getting about 310-315 hp. And with the total weight of the car just under 3000 lb., it does all right.
[Re: nitrohemi]
#51648
01/17/10 11:06 PM
01/17/10 11:06 PM
Posts: 1,668 Mi,U.S.A.
mike s
Mi,U.S.A.
Here is one I saw at the annual Lansing,Mi show.
Leave the gun.......take the Cannoli's....Mike
[Re: Ply36]
#51650
01/21/10 12:15 PM
01/21/10 12:15 PM
fstfish66
levittown pa
315 hp out of a 241 ?? did you have custom high compression pistons made? with stock pistons 7.1 compresion,,factory hp is 140 with a 2 bbbl., i think it would be very hard to double thet hp with out bigger compression
[Re: Ply36]
#51652
01/22/10 01:24 PM
01/22/10 01:24 PM
fstfish66
levittown pa
very kool...what did those cost to have made??
i returned the pic you e mailed me,,i resized it by 75%
[Re: Ply36]
#51654
01/26/10 03:23 AM
01/26/10 03:23 AM
fstfish66
levittown pa
was that for 8 or 10 ? some times special order pistons are made in 10 units,,,at least they use to be or some one did,,,lol whats the cam you have??
[Re: fstfish66]
#51655
01/26/10 09:10 PM
01/26/10 09:10 PM
Posts: 296 Michigan
Ply36
that's for eight. if it had been for ten, the other two would have been made into trophies. at least it would seem like more of a bargain that way. As to the cam, luckily it was good enough to be reground by Isky Cams. Here's another interesting story by the shop that did the engine; Ol' Ed Iskendarian himself, now retired, sometimes still likes to come in the shop and run through some cams. When mine came in, supposedly he reground it. Don't know if it's true, but makes for a fun story. Just to clarify; the engine builder was in Lansing, MI and sent the cam out to Isky,
[Re: Ply36]
#51656
01/29/10 04:31 PM
01/29/10 04:31 PM
fstfish66
levittown pa
very kool....do you happen to know the new specs on the re ground cam ?? so if i want a set of 10.1 pistons for my 241 JE now has a mold?? got a phone number or contact person?? and did you get the resized photo of your car i returned to you???? where are you located?? PA here
[Re: Ply36]
#51658
02/09/10 01:56 AM
02/09/10 01:56 AM
fstfish66
levittown pa
ok great thanks,,, i made a copy of what you said,,,
