What cam for this combo of 440
#516109
11/04/09 07:12 PM
11/04/09 07:12 PM
Posts: 348 Iceland
70rtshaker
super street
super street
Iceland
I am rebuilding a 440 0.030 over that was rebuilt 20 years ago ( has been sitting most of the time since), I am looking for as much torque as possible for the street, what I have and want to use is the following as this is a tight budget project.
11.5:1 dome MP pistons Edelbrock Performer RPM intake Stealth Alu head (440 source) Harland Sharp Roller rockers Hooker headers 1 7/8"
I would like to run a hyd cam (non roller) to gain as much torque as possible. Rev probaly at 5500 top.
Any suggestions what cam would work best for this combo ??
Thordur Ingvarsson, Reykjavik Iceland
1970 Dodge Challenger R/T 440 sixpack Shaker(sold)
1971 Plymouth Cuda pro-street project
2007 YAMAHA YZF R1 189 HP
2007 YAMAHA FZ1 SA 150 HP
2003 Mercedes Benz E-200 Kompressor 163 HP
toti62@internet.is
Re: What cam for this combo of 440
[Re: Dougsmopars]
#516111
11/04/09 07:37 PM
11/04/09 07:37 PM
Posts: 348 Iceland
70rtshaker
super street
super street
Iceland
Cant find that cam on Lunati website, could you be more specific, thanks
toti62@internet.is
[Re: DaytonaTurbo]
#516113
11/05/09 03:22 AM
11/05/09 03:22 AM
Posts: 348 Iceland
70rtshaker
super street
super street
Iceland
As I understand the Stealth heads are supposed to have 85cc chamber vol according to 440source.com and I have read somewhere that alu heads consump 1 compression so I would be looking at actual 10.5:1, does this make sense?
toti62@internet.is
[Re: 70rtshaker]
#516114
11/05/09 04:01 AM
11/05/09 04:01 AM
Posts: 4,861 Riverside, Ca
R70RUNNER
Riverside, Ca
That's a rule of thumb... Not sure what you have for pump gas there???(R+M/2) even 10.5 with aluminum heads could be dicey unless proper qunech/squish. I'm a big fan of the Lunati Voodoo cams (well designed with the 904 lifter bores.) I'd look at the 60304
Current cars: 2000 Dak Quad Cab, 2012 Challenger,1970 Road Runner, 1994 Firehawk
1966 Coronet post sedan, 1988 Corvette, 2005 Magnum RT all SOLD
R70RUNNER<---VP Inland Empire Chapter of the MPM
[Re: gch]
#516116
11/06/09 10:44 AM
11/06/09 10:44 AM
RapidRobert
After you finalize your cam selection I'd find what the max dynamic compression ratio is for your intended octane, mill/deck for .040" quench (in every hole)/and for the static CR to get that DCR
