Mill intake port side after decking & shaving heads #512318
10/31/09 12:56 PM
10/31/09 12:56 PM
Sweden
6pakdude Offline OP
6pakdude  Offline OP
Sweden
My rebuilt 440-6 is sucking in oil at the lower intake port side. oil in intake manifold and on top of intake valves?
Need to mill the org alu 6pak manifold to seal against the port side of heads.
Block decked 0,024"
Heads shaved 0,016"
Total 0,040"
Use felpro 0,039" head gasket
Org steel gasket 0,020" head gasket
Total extra height 0,019"
So I figure 0,040" milled
thicker head gasket + 0,019"
So total milled surface is 0,021"
Put intake valley pan back with 0,016" gasket at lower side on intake on each side, Tighten everything up and tried to get a 0,002" shim in at top of intake.very tight.
So I was thinking taking of 0,014" on each side, at the TOP side of manifold, and 0" at LOWER side at the intake, and would end up with 0,014" egual to head surface.
Making or buying intake gaskets 2 pc 0,014" thick.
Need your advice and input on this before milling.
Re: Mill intake port side after decking & shaving heads [Re: 6pakdude] #512319
10/31/09 01:30 PM
10/31/09 01:30 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Right stuff, high temp silicone,
use liberally tighten lightly wait 2 hours, tighten fairly snug, wait over night snug again. warm up and tighten check after cooling and check after a week the periodically
Re: Mill intake port side after decking & shaving heads [Re: 6pakdude] #512320
10/31/09 01:43 PM
10/31/09 01:43 PM
I'd check that the angle of the intake and the angle of the head intake face is the same (& flat)& in addition mill enough so the intake ports end up being perfectly aligned with the head ports.
Re: Mill intake port side after decking & shaving heads [Re: 6pakdude] #512321
10/31/09 02:16 PM
10/31/09 02:16 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
For every .010 taken off the head surface if you would have .0123 taken off the intake side of the head you wouldn't have to touch the intake.
Re: Mill intake port side after decking & shaving heads [Re: 62maxwgn] #512322
10/31/09 02:21 PM
10/31/09 02:21 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
This is the right way to do it then there wouldn't be so many intakes floating around with the bolt holes ovaled out/cracked or cut to fit that specific combo making it useless for others...
