My rebuilt 440-6 is sucking in oil at the lower intake port side. oil in intake manifold and on top of intake valves?
Need to mill the org alu 6pak manifold to seal against the port side of heads.
Block decked 0,024"
Heads shaved 0,016"
Total 0,040"
Use felpro 0,039" head gasket
Org steel gasket 0,020" head gasket
Total extra height 0,019"
So I figure 0,040" milled
thicker head gasket + 0,019"
So total milled surface is 0,021"
Put intake valley pan back with 0,016" gasket at lower side on intake on each side, Tighten everything up and tried to get a 0,002" shim in at top of intake.very tight.
So I was thinking taking of 0,014" on each side, at the TOP side of manifold, and 0" at LOWER side at the intake, and would end up with 0,014" egual to head surface.
Making or buying intake gaskets 2 pc 0,014" thick.
Need your advice and input on this before milling.
