440 Engine Pad Decoding #51088
01/04/08 06:25 PM
01/04/08 06:25 PM
State of Flux
Dodge Don Offline OP
State of Flux
I ran across a 70 440 block that has an oddity I cannot decode. The casting number is the right 2536430-8 but on the pad itself it reads:
F440 Upside down "C"
3 4 HP
The engine appears to be a 70 Six Pack.
What does the upside down C mean?
Thanks.
Re: 440 Engine Pad Decoding [Re: Dodge Don] #51089
01/04/08 06:36 PM
01/04/08 06:36 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
APPEARS ????? to be ??
the upside down C supposedly means it has a special crankshaft , but what that exactly means is ?????
is it rebuilt , a block , a shortblock , untouched ????
Re: 440 Engine Pad Decoding [Re: JohnRR] #51090
01/04/08 07:29 PM
01/04/08 07:29 PM
all 440's are 6-packs
just like all chev 350's are LT1s
Re: 440 Engine Pad Decoding #51091
01/04/08 07:59 PM
01/04/08 07:59 PM
State of Flux
State of Flux
Smart [Edited by Moparts - Keep it clean].
The engine needs a rebuild, block looks untouched (other than being torn down) and has the six pack crank and connecting rods. That and the engine shop that has it says it came from a six pack car. The engine was dropped off for a rebuild awhile ago and work started but then divorce hit, couldn't pay the bills and forfeited the engine block in lieu of payment.
Re: 440 Engine Pad Decoding [Re: Dodge Don] #51092
01/04/08 08:21 PM
01/04/08 08:21 PM
God's Country Maryland
GODSCOUNTRY340 Offline
The "C" on the pad means "Special Rods & Pistons". That is a six pack block. There should also be a "C" on another spot on that block if it's a real six pack and someone hasn't just put the C on the pad. I'll PM you with that location.
Re: 440 Engine Pad Decoding [Re: GODSCOUNTRY340] #51093
01/04/08 09:10 PM
01/04/08 09:10 PM
lewiston, ID
cornucopia Offline
cornucopia  Offline
lewiston, ID
so it's a secret??? I thought this was a "question & answer" board...just think the havoc I could wreck if I knew the secret location of the magical "C" stamp.
Re: 440 Engine Pad Decoding [Re: cornucopia] #51094
01/04/08 09:14 PM
01/04/08 09:14 PM
i think he's talking about about the stamp on the back of the engine by the cam plug.
Re: 440 Engine Pad Decoding #51095
01/04/08 10:18 PM
01/04/08 10:18 PM
There are hidden numbers and symbols on all vehicles that the general public doesn't know about. These are put there for reasons you should be able to figure out. The world is filled with scam artists, car thieves, chop shops. Just ask the people that have been ripped off by them. If everybody knew where these were there could be no justice, the criminals would win. There are more out there than you think. I've dealt with many of them.
Re: 440 Engine Pad Decoding [Re: GODSCOUNTRY340] #51096
01/05/08 12:34 PM
01/05/08 12:34 PM
State of Flux
State of Flux
Thanks. Looks like we are going to use that block for my six pack build up and they'll keep my 75 440 block in trade. At least the engine block will be the correct year now.
Re: 440 Engine Pad Decoding [Re: GODSCOUNTRY340] #51097
01/05/08 02:06 PM
01/05/08 02:06 PM
East Aurora (Buffalo) NY
RoadRunner Offline
RoadRunner  Offline
There are hidden numbers and symbols on all vehicles that the general public doesn't know about. These are put there for reasons you should be able to figure out. .....
When you do a rotiserrie resto removing gunk with 1" metal brushes, you see every nook and cranny on a car. I can tell you that in 69, there weren't a whole lot of numbers on panels. Other than the two places for vin stampings, there really isn't anything else. The various numbesr and letters on the engine do tell you a whole bunch. removing the oil pan will reveal stampings to show if any (and which one) rods or mains are under/over size. Factory service manual will tell you the meaning of most of these.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project
69 Road Runner w/472 Hemi & 4 speed.
70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project
2023 Ford Mach 1
Re: 440 Engine Pad Decoding [Re: RoadRunner] #51098
01/05/08 02:14 PM
01/05/08 02:14 PM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Sorry dude, I'm calling BS on that one, I've owned more than one numbers matching 1970 440 Six Pack car and NONE of them have had the magical "C" you mentioned. I'm not saying that SOME may have had a "C" stamp, but it's certainly not something that positively identifies any 440 as a six pack block, there is only one way to do that and that is to match the blocks VIN sequence# to an original 440 Six pack car, as far as cranks and rods go, all 70 440's used the same rods and cranks, the Six Packs did use unique pistons which had valve reliefs on both sides, but that's an easily changed out componant so unless you know for certain the engines never been appart it's not sure bet. PERIOD END OF STORY!
Same goes for your comment about "secret" numbers stamped into cars in hidden places (other than the already well known locations). I hate crooks and thieves as well but that's pure fantasy urban legend.
Re: 440 Engine Pad Decoding [Re: ScottSmith_Harms] #51099
01/05/08 02:29 PM
01/05/08 02:29 PM
Kansas 67208
8
8_Barrel Offline
super gas
8_Barrel  Offline
super gas
8
Kansas 67208
....I've owned more than one numbers matching 1970 440 Six Pack car and NONE of them have had the magical "C" you mentioned......
Just curious, have you had the bathtub/intake gasket off on all those 'matching numbers' cars? And I'm thinkin' the 'C' six-pak reference is for 69 1/2 cars.
If you "Ain't Skeered" or have "No Fear", it's 'cause you ain't goin' FAST enough!!
Re: 440 Engine Pad Decoding [Re: 8_Barrel] #51100
01/05/08 02:39 PM
01/05/08 02:39 PM
State of Flux
State of Flux
This block was built January 28, 1970 so the reverse C cannot have anything to do with A12 cars.
Re: 440 Engine Pad Decoding [Re: Dodge Don] #51101
01/05/08 02:42 PM
01/05/08 02:42 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
I've never owned one with the original intake gaskets, they'd all been R&R'd at one time or another, but I do have good clear photos of the block pad stampings as well as the block VIN# sequence stampings and matching VIN tags if you ever need to see proof to say, settle a bet?
Re: 440 Engine Pad Decoding [Re: Dodge Don] #51102
01/05/08 03:21 PM
01/05/08 03:21 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
has the 6pk crank ???
does the shop still have the pistons they removed from that engine ???
i'm not buying the its a 6 pk because every knows that a 6pk block is an HP2 ...
Re: 440 Engine Pad Decoding [Re: JohnRR] #51103
01/05/08 03:49 PM
01/05/08 03:49 PM
eganville ont
440beep Offline
440beep  Offline
eganville ont
all 70-71 440 hp 440 4bbl or 6bbl have a six pack crank and connecting rods and damper hemi oil pan
the 70 6bbl has 10.5 pistons 4bbl has 9.7
716bbl has 10.3 4bbl 9.5
the 70-71 440 lp do not have them
Re: 440 Engine Pad Decoding [Re: 440beep] #51104
01/05/08 04:02 PM
01/05/08 04:02 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
So what's the VIN year/plant/sequence off the side of the block?
Re: 440 Engine Pad Decoding [Re: 6bblgt] #51105
01/05/08 06:11 PM
01/05/08 06:11 PM
State of Flux
State of Flux
It's a St. Louis plant block, 1970, late year VIN sequence, I've already checked the 70 Charger and Six Pack Registries and the VIN is not registered.
Frankly, all I was interested in was what the upside down C meant. They are going to take my incorrect year 440 block and use the 70 block for my build. Which is a bonus for me. It wasn't #s matching going in but it'll be at least the right year now.
Oh and my understanding is that HP2 does not mean anything other that second shift of production.
Re: 440 Engine Pad Decoding [Re: Dodge Don] #51106
01/05/08 06:14 PM
01/05/08 06:14 PM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Well yes, the 2 portion of it does. HP stands for High Performance, which would have been on any 440+4 HP or any 440+6 engine.
Re: 440 Engine Pad Decoding [Re: ScottSmith_Harms] #51107
01/06/08 12:50 AM
01/06/08 12:50 AM
Kansas 67208
8
8_Barrel Offline
super gas
8_Barrel  Offline
super gas
8
Kansas 67208
I wasn't asking if they had original valley pan gasket, rather I was asking if you had viewed the complete pad. I've noticed that as a general rule, the 'C' is at the back of the pad and the valley pan is usually covering it.
