christmas time and some b1 questions #509166
10/27/09 08:09 PM
10/27/09 08:09 PM
duluth,mn
P
psycomopar Offline OP
P
duluth,mn
well getting all my parts together for the new engine for the mirada. just got my b1 heads and world block. waiting on rotating assembly from muscle motors.(pistons are getting made.also have a few questions on b1 heads. how thick are the spacers for the intake?someone have a set laying around that they could measure? and where do you put the oil drain holes that i have seen and have heard are needed?any other info would greatly be appreciated on setting them up to run.right know they are new in the boxes that some never used so i have to send somewhere to get set up. thanks much
Re: christmas time and some b1 questions [Re: psycomopar] #509167
10/27/09 11:49 PM
10/27/09 11:49 PM
SoCal
Brian Hafliger Offline
SoCal
Brian Hafliger
Re: christmas time and some b1 questions [Re: Brian Hafliger] #509168
10/28/09 12:08 AM
10/28/09 12:08 AM
Finland
Hessu Offline
Hessu  Offline
Finland
Re: christmas time and some b1 questions [Re: psycomopar] #509169
10/28/09 12:14 AM
10/28/09 12:14 AM
Las Vegas
Al_Alguire Online laugh2
Las Vegas
What rockers are you planning on running? The link is up for where the oil drain luines go, from my experience make them as large as you can. They can hold a good deal of oil if the lines are to small. Mine drain into the pan itself.
Re: christmas time and some b1 questions [Re: Al_Alguire] #509170
10/28/09 12:25 AM
10/28/09 12:25 AM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
Hope this helps, we put 8AN fittings on both ends and ran them into the pan.
Re: christmas time and some b1 questions [Re: Al_Alguire] #509171
10/28/09 07:45 AM
10/28/09 07:45 AM
duluth,mn
P
P
duluth,mn
al i think im running the out of the box rockers.unless i come across a deal on a set of t&d , jesels ect. thanks oil drain hole info .do you just go into the side of the oil pan?
Re: christmas time and some b1 questions [Re: psycomopar] #509172
10/28/09 10:14 AM
10/28/09 10:14 AM
Las Vegas
Las Vegas
Yes I have bungs welded into my pan. 4 of them to be exact. Did the saem thing on the Valiant and I use -8 lines.
I will keep an eye out for some rockers. I ran the T&D common shaft set up on the Valiant and they worked great and do not require any additional machining to the heads like the individuals do. They have thier limitation but not until you get inta crazy springs and cams.
Re: christmas time and some b1 questions [Re: Al_Alguire] #509173
10/28/09 09:20 PM
10/28/09 09:20 PM
NW PA
V10nacuda Offline
V10nacuda  Offline
NW PA
Be sure if you use the T&D's that you check the tips for siezing.... Soaked mine in oil as directed & still had 2 that needed re worked & one got a new pin.
V10
Re: christmas time and some b1 questions [Re: Al_Alguire] #509174
10/28/09 09:47 PM
10/28/09 09:47 PM
duluth,mn
P
P
duluth,mn
Al, do you put a drain on front and back of head. i seen you said you have 4 lines
Re: christmas time and some b1 questions [Re: psycomopar] #509175
10/28/09 11:22 PM
10/28/09 11:22 PM
Las Vegas
Las Vegas
Tes I have drains in the front and rear of the engine, have always don tit that way. As for the T&D point made never been an issue for me but like ALL B1 combos pushrod length is very critical.
Re: christmas time and some b1 questions [Re: Al_Alguire] #509176
10/28/09 11:30 PM
10/28/09 11:30 PM
land of the free
ts racer Offline
ts racer  Offline
land of the free
A drain in the back of the head for oil is the best bet.
Would not hurt to add a water 6or 8an fitting in between the center exhaust to help cool the heads.
The indy reverse flow block also helps.
T&D are the best rockers for the b1 stuff.
We like to oil thru spray bar.
Get a good set of lifters with a oiling hole for the roller.
Re: christmas time and some b1 questions [Re: ts racer] #509177
10/28/09 11:34 PM
10/28/09 11:34 PM
Las Vegas
Las Vegas
Good point I forgot to mention the water port. helps with hot spots. I also use a Mezeiere revers flow water pump as well. On mine I have pushrod oiling. So far no issues with rockers or pushrods with my springs pressure whichis not weak at 1050 over the nose.
Re: christmas time and some b1 questions [Re: Al_Alguire] #509178
10/29/09 09:44 AM
10/29/09 09:44 AM
Eagleville Tn.
rtstreet Offline
rtstreet  Offline
Eagleville Tn.
pic of mine
Re: christmas time and some b1 questions [Re: rtstreet] #509179
10/29/09 09:46 AM
10/29/09 09:46 AM
Eagleville Tn.
rtstreet Offline
rtstreet  Offline
Eagleville Tn.
one more and mike at muscle did mine
Re: christmas time and some b1 questions [Re: Al_Alguire] #509180
10/29/09 12:06 PM
10/29/09 12:06 PM
sg66mopar Offline
sg66mopar  Offline
Are there no drain holes in the heads from the rocker box to the valley or are they just insufficient?
Re: christmas time and some b1 questions [Re: sg66mopar] #509181
10/29/09 02:46 PM
10/29/09 02:46 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
there are no drains in the heads, you need to add them at the ends as pictured
Re: christmas time and some b1 questions [Re: jamesc] #509182
10/29/09 08:25 PM
10/29/09 08:25 PM
duluth,mn
P
P
duluth,mn
thanks guys for all the info.i suppose im going to have to keep an eye out for a set of rockers also. there is alittle more work than expected but will be well worth it when done.i just put heads on block. how do you machine block for pushrods? anyone have to have that done yet?also where do you run that coolant line in the heads to the rad ,waterpump?
Re: christmas time and some b1 questions [Re: psycomopar] #509183
10/29/09 11:30 PM
10/29/09 11:30 PM
State of retirement
52savoy Offline
52savoy  Offline
State of retirement
I guess you found the rocker shaft blocks?
Hated to get rid of the heads but sometimes things don't go as planned.
Fred
Re: christmas time and some b1 questions [Re: psycomopar] #509184
10/30/09 01:05 AM
10/30/09 01:05 AM
Las Vegas
Las Vegas
My water lines are tapped into the block, the main water passages where the pump mounts. You will need to do a little/a lot of blending in where the pushrod holes are as well depending on rockers, pushrods used and cam profile. I run HUGE pushrods so there is a good deal of work done in that area as well.
Re: christmas time and some b1 questions [Re: Al_Alguire] #509185
10/30/09 06:09 PM
10/30/09 06:09 PM
land of the free
ts racer Offline
ts racer  Offline
land of the free
Here is a pic of the rear of the heads, oil drains and fitting for the water.
