Page 3 of 4 1 2 3 4
Re: W9 or P7 ? [Re: Leon441] #50912
12/31/07 08:24 PM
12/31/07 08:24 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
P5? You've got to find them first!
The P7 stuff will make good power, and there's plenty of stuff out there. When you've got a new block coming out, it would make sense to play around with some combinations for prospective clients.
AL....
Alan Jones
Re: W9 or P7 ? [Re: LA360] #50913
01/02/08 10:46 AM
01/02/08 10:46 AM
Charleston, SC
SCDaytona Offline
SCDaytona  Offline
Charleston, SC
If Rick wanted P5's, he could get them pretty easily.
Re: W9 or P7 ? [Re: SCDaytona] #50914
01/16/09 01:23 AM
01/16/09 01:23 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Due to the lack of the "other" blocks I just got an R5 for my R5/P7 build.
How many different p-7 intakes are out there....Ive only one...sorta looks like a mini pred intake.
Re: W9 or P7 ? [Re: LA360] #50915
01/16/09 10:25 AM
01/16/09 10:25 AM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
A couple of points to consider.
I have heard that the W9 heads are thin on top and agressive profiles & high RPMS will crack the rocker supports.
There is a 80lb gain with the R5 block.
Hope this helps
8.30's @3400 lbs
Re: W9 or P7 ? [Re: Mike Swann] #50916
01/16/09 11:03 AM
01/16/09 11:03 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Hope this helps
I dont know what your refering to thin but the valve
cover area is thinner(so called light weight), on
the rocker area, if you use the good rockers, like
TD or Jesel you wont have a problem(at least I havent)
but I have only been turning mine to 8200 rpm but
have been as high as 8600rpm and I dont have any
problems on the rocker mounts. I heard from the race
group at work that they did have pedistal problems
cracking when they first brought out the W-9 but
havent heard of it since then
Re: W9 or P7 ? [Re: quick77rt ] #50917
01/16/09 11:11 AM
01/16/09 11:11 AM
Carbondale PA
Domino1609 Offline
Domino1609  Offline
Carbondale PA
Actually there were quite a few intake manifolds made for the R5/P7 combination.
I have a few of each here, some of what I have are no longer NASCAR legal, I am not sure why but that is a fact so if you need pictures or info I will try to help.
We have built and dynoed about every combination of parts that are available for the R5-P7 (most in roller cam form) and to be honest I think the port work means more than the part number.
Certainly there are a few manifolds that have much larger volume than others, but as changes were made and time went on the runners became shorter. No doubt the intent was to move peak power up higher in the RPM range.
I have one motor here that makes peak at 9300, not that long ago this thing would have been a decent Comp Eliminator motor, think about it this way, it has a cast manifold, a circle track style cam, 12.5 Compression and was dynoed with a nothing carb.It makes almost 2.4 per cube with break in oil. A few modest changes and it can still be very good.
Actually we are having a few sheet manifolds made for these things, if you think you want to go down that road let us know.
Rick
Re: W9 or P7 ? [Re: Domino1609] #50918
01/16/09 11:20 AM
01/16/09 11:20 AM
mid Ga.
W5Dart378 Offline OP
mid Ga.
There are quite a few P7 intakes:
69 340 swinger streetcar 8.13 1/8th w/1.90 60ft w/ 3.55s 69 422W9 Dart stock suspension,5.27 on 275/60s,single bar plate
Re: W9 or P7 ? [Re: W5Dart378] #50919
01/16/09 11:24 AM
01/16/09 11:24 AM
mid Ga.
mid Ga.
2819:
Re: W9 or P7 ? [Re: W5Dart378] #50920
01/16/09 11:26 AM
01/16/09 11:26 AM
mid Ga.
mid Ga.
Re: W9 or P7 ? [Re: W5Dart378] #50921
01/16/09 11:28 AM
01/16/09 11:28 AM
mid Ga.
mid Ga.
Re: W9 or P7 ? [Re: W5Dart378] #50922
01/16/09 11:29 AM
01/16/09 11:29 AM
mid Ga.
mid Ga.
And another,
Re: W9 or P7 ? [Re: W5Dart378] #50923
01/16/09 11:38 AM
01/16/09 11:38 AM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
Thanks for the intake pics and info, I should be good with mine then since im not trying to squeeze max power.
Although do know one of the intakes makes a few more approx 20 #-s torque at a lower rpm but takes it off the top.
Thanks again.
Re: W9 or P7 ? [Re: W5Dart378] #50924
01/16/09 11:39 AM
01/16/09 11:39 AM
mid Ga.
mid Ga.
Wow this is an old thread.
I'm planning to do a P7 one day. I'm just now getting my W9s on my X block now. On the heads cracking I could see an issue with max porting and the older rocker mount that doesn't have the extra bolt on the ends.
In the classes around hear that my car fits in like ORSCA Modified street, canted valve heads require +100#., and I believe the Realstreet class in Floridia they aren't allowed.
Re: W9 or P7 ? [Re: W5Dart378] #50925
01/16/09 11:56 AM
01/16/09 11:56 AM
MR_P_BODY Offline
MR_P_BODY  Offline
The one thing I'd like to make for my W-9s is a set
of studs for the rocker hold downs that stays in the
head, I've cut the bolts in the intake port for flow
but everytime I take the rockers off I have to make
sure I put the right bolt in the right hole so it
matches up in the port. With the studs I could leave
them in
Re: W9 or P7 ? [Re: MR_P_BODY] #50926
01/16/09 11:59 AM
01/16/09 11:59 AM
Long Beach, CA
Mike Swann Offline
Mike Swann  Offline
Long Beach, CA
Hope this helps
I turned my 540 to 8600 on every pass.
8.30's @3400 lbs
Re: W9 or P7 ? [Re: Mike Swann] #50927
01/16/09 12:05 PM
01/16/09 12:05 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'd go higher if it made power, but mine peaks at
8100 rpm and I cross the line at 8200 so thats all
it takes for me. My new 514 should be a 8500 to 9000 rpm
engine
Re: W9 or P7 ? [Re: MR_P_BODY] #50928
01/16/09 12:37 PM
01/16/09 12:37 PM
PA
68CudaB1 Offline
68CudaB1  Offline
PA
When I spoke to CFE about this same topic here is what they told me.....
A W8 is the better head for all out N/A apps, they did not want anything to do with a W9 casting.
A W8 head will outperform a P7 head IF THE P7 does not have a sheetmetal setup....if the P7 has a sheetmetal, then it will dominate..
They also told me that they were confident that their W8 head would support 1000HP out of 420" and still do it with 15* valve angle
Re: W9 or P7 ? [Re: 68CudaB1] #50929
01/31/09 06:28 PM
01/31/09 06:28 PM
LA360 Offline
LA360  Offline
For the coin, the P7 stuff that is around is hard to beat for what you pay. I know first hand what you will spend with CFE for a top end, that money will basically buy you a fresh R5/P7 engine.
W9 heads were designed with a very specific purpose (Dirt Oval Track), where as the W8 had to where several caps figuratively speaking.
If I was looking to build a small block that made 800+ HP I wouldn't look at anything but a P7 head these days.
JMO anyway
AL....
Alan Jones
Re: W9 or P7 ? [Re: W5Dart378] #50930
07/22/09 02:33 PM
07/22/09 02:33 PM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
with what i have seen with my buddies extremely tame p7 motor thus far, i think the p7 head is going to have way more potential than a w9 head. just my opinion.
I think with that new block, longer stroke it will allow, it will be hard to keep an optimized combo out of the 8's just on motor even at the weight you are talking. He has already been almost 141 mph with a tiny cam, 12 to 1 compression, and zero tuning at 358 inches using the belt to drive the water pump . Lots of upside to the p7 head with that new block.His convertor was behind another combo nothing like the p7 motor he has, so there is a ton of et in getting that sorted out as well.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: W9 or P7 ? [Re: B3422W5] #50931
07/22/09 07:10 PM
07/22/09 07:10 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Jeez Don, are you board? Bringing back posts from the dead 6 months later...lol...
Page 3 of 4 1 2 3 4
