440 Valve Adjusting #507823
10/26/09 12:31 PM
10/26/09 12:31 PM
Omaha, NE
dart69bigblock Offline OP
Omaha, NE
I am new at working with Chrysler engines. Can someone give me a quick run down on how to adjust the valves on a 440. It has aftermarket aluminum adjustable rockers.
Re: 440 Valve Adjusting [Re: dart69bigblock] #507824
10/26/09 12:46 PM
10/26/09 12:46 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
Follow the 273 or T/A valve adjustment instructions on the sticker, ie TDC then adjust intake on valves X and y, exhaust on valves y and z. Rotate crank 90 and then do these other valves, etc. Basically, you are adjusting the valves on the base circle of the cam lobe and the crank position helps. If you cant find the instructions, you are safe adjusting the valve in the cylinder when the other valve just starts lifting.
12 Grand Caravan
06 T&C
02 T&C
96 Breeze
65 Barracuda "S"
Re: 440 Valve Adjusting [Re: dart69bigblock] #507825
10/26/09 01:33 PM
10/26/09 01:33 PM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
Solid or hydraulic lifters?
This is the land of the free because of the brave
Re: 440 Valve Adjusting [Re: rbstroker] #507826
10/26/09 01:39 PM
10/26/09 01:39 PM
Imlay City, MI
DTT Offline
super gas
DTT  Offline
super gas
Imlay City, MI
1978 Pro Street D100 1936 Dodge truck (Hot rod) 1957 Plymouth Plaza 1962 Chrysler 300 1964 Dodge 440 1995 Jeep Grand Cherokee 1971 Big Block Demon (Dads)
Re: 440 Valve Adjusting [Re: DTT] #507827
10/26/09 02:11 PM
10/26/09 02:11 PM
ILL
MLR426 Offline
MLR426  Offline
ILL
Do one cylinder at a time.
When the exhaust starts to go down set the intake.
When the intake is almost at the top set the exhaust.
logan426
Re: 440 Valve Adjusting [Re: MLR426] #507828
10/26/09 03:15 PM
10/26/09 03:15 PM
"Rockover" method. pull plugs/turn crank w 1&1/4" socket & breaker bar. turn it until the both valves on #1 cyl are moving and are at the same height, at that point adj the clearance on #6. Then turn it until both valves on #6 are moving and are at the same height, at that point adj the clearance on #1. Then go to the next vertical column (8 & 5) & repeat(disregard the A & B) & then the next 2 columns. If the spec is for example .020", a .019" flat feeler gauge should have no drag and a .021" gauge should have light drag & with the gauge held square this will get you within .001" of your spec. EDIT forgot the diagram (it's Monday)
Re: 440 Valve Adjusting [Re: dart69bigblock] #507829
10/26/09 04:24 PM
10/26/09 04:24 PM
oregon
ramcharger1964 Offline
oregon
This is directly from Damon Kuhn at Diamondback:
"Double check them before you fire (cold)-they should be .004 or so (+/-.002) LOOSER than the spec- warm it up and adjust to spec- turn it by hand or bump it on the starter unntil the exhaust for the cylinder you are adjusting is just beginning to open- adjust the intake to spec at that point. Then roll all the way thru the exhaust opening and closing and the intake opening and when it is almost closed or just barely closed (in that range) , adjust the exhaust. Doing it this way insures the most accurate setting and allows going from front to rear on the drivers side and the same on the passenger side- you should only have to turn more than a bump when doing number 8"
Hell B!tch Racing Co.
