u-bolt torque specs #507646
10/26/09 09:53 AM
10/26/09 09:53 AM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
anyone know the torque specs on dana 60 u-bolts? thanks
Re: u-bolt torque specs [Re: mopar dave] #507647
10/26/09 11:14 AM
10/26/09 11:14 AM
organ
maximum entropy Offline
organ
depends o the size of the bolts. iirc the stock is not real tight- maybe 60 or so? i have 9/16 u bolts that i torque to 80 ft lbs.
Re: u-bolt torque specs [Re: maximum entropy] #507648
10/26/09 11:19 AM
10/26/09 11:19 AM
Mt Morris Michigan
Mt Morris Michigan
the u bolts are 1/2".
Re: u-bolt torque specs [Re: mopar dave] #507649
10/26/09 11:22 AM
10/26/09 11:22 AM
Q
Quicktree Offline
Quicktree  Offline
Q
don't know never torqued one. as tight as I can get them with a hand wrench.
Re: u-bolt torque specs [Re: mopar dave] #507650
10/26/09 12:31 PM
10/26/09 12:31 PM
organ
organ
here's the official word- 1/2" ubolts- 65 ft lbs, recheck at 50 miles, again at 100, at 500, and every time under the car after that. never reuse u bolts. never use lock washers. use hardened flat washers.
Re: u-bolt torque specs [Re: maximum entropy] #507651
10/26/09 01:36 PM
10/26/09 01:36 PM
Mt Morris Michigan
Mt Morris Michigan
ok, but why can't u bolts be reused? as hard as the nuts came off i can't immagine them coming loose.
Re: u-bolt torque specs [Re: mopar dave] #507652
10/26/09 01:40 PM
10/26/09 01:40 PM
organ
organ
my source was eaton spring, so maybe they're just trying to boost u bolt sales? i change mine every couple of years. if they've been in service for a while, i'd change 'em. and go bigger while you're at it!
Re: u-bolt torque specs [Re: maximum entropy] #507653
10/26/09 01:59 PM
10/26/09 01:59 PM
Mt Morris Michigan
Mt Morris Michigan
ok, thanks
Re: u-bolt torque specs [Re: mopar dave] #507654
10/26/09 11:01 PM
10/26/09 11:01 PM
The OEM nuts are a locking type nut(look for the identation half way down in the center on two sides ) the Mopar service manuals call for 55 FT lbs. on the stock 1/2 inch U bolts and stock nuts, no lock washers or flat washers from the factory, they are to cheap to use them or pay someone (in the UAW) to install them
