Do I need a new power steering box? #504112
10/22/09 07:47 PM
10/22/09 07:47 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
Here's what I know so far:
I have about 15° of play in my steering wheel before steering action happens. The wheel is free to move within this but after the 15°, it encounters resistance and starts to steer.
I have checked the steering componentry while someone else is turning the wheel in this 15° window, and none of the components are moving. The pitman arm, the tie rod ends, the idler arm, nothing moves. Once you get past that window, however, they start to move.
I have tightened up the box multiple times from the cross-shaft adjustment screw, thinking that maybe it still wasn't tight enough. I finally got to the point where it was almost impossible to turn the wheel, so I backed it back off to a better position, but still there's play. Also, the play has been there since I bought the car.
There is no pump pressure to the box right now, but looking at the cross-section of the steering box, it looks like the pressure just makes it easier to steer (read: after the 15° window), not actually tighten the steering up.
I think it's time for a new box, but I wanted to get the opinions of others first. Thanks in advance!
Re: Do I need a new power steering box? [Re: sharpie] #504113
10/22/09 07:52 PM
10/22/09 07:52 PM
is the 15 deg of play w it running or not running?
Re: Do I need a new power steering box? [Re: RapidRobert] #504114
10/22/09 07:54 PM
10/22/09 07:54 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
both.
Re: Do I need a new power steering box? [Re: sharpie] #504115
10/22/09 08:04 PM
10/22/09 08:04 PM
certainly shouldn't have that kind of play running but cant tell if the cross shaft adjustment is off or if the box as you suspect is bad
Re: Do I need a new power steering box? [Re: RapidRobert] #504116
10/22/09 08:08 PM
10/22/09 08:08 PM
hooziewhatsit Offline
my W200 is the same way. Everything seems tight, but the wheel is sloppy. I don't like driving any faster than 60mph due to it. My wife won't drive it at all.
I got a rebuilt box, that was either bad also, or they're just sloppy by design, as the new box made no difference
Re: Do I need a new power steering box? [Re: hooziewhatsit] #504117
10/22/09 08:54 PM
10/22/09 08:54 PM
renton, Washington
ph23vo Offline
ph23vo  Offline
renton, Washington
is the frame cracked around the box or the bolts loose? dan
Re: Do I need a new power steering box? [Re: ph23vo] #504118
10/22/09 09:04 PM
10/22/09 09:04 PM
Poplar Bluff, Mo. 63901
2
268RTs4ME Offline
268RTs4ME  Offline
To start with, what vehicle are you working on? Check out your coupling
Re: Do I need a new power steering box? [Re: 268RTs4ME] #504119
10/23/09 02:38 AM
10/23/09 02:38 AM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
It's my 71 Demon. The box isn't moving within the 15º window. It also doesn't move after the window. I can check the coupler, but the splines on the box that connect to the coupler move whenever the steering shaft moves. So they seem to be in alignment.
Re: Do I need a new power steering box? [Re: sharpie] #504120
10/23/09 05:23 AM
10/23/09 05:23 AM
rochester,new york
P
plumebody Offline
plumebody  Offline
P
rochester,new york
I think OLDMAN has one for sale. Maybe shoot him a PM
Re: Do I need a new power steering box? [Re: plumebody] #504121
10/23/09 10:15 AM
10/23/09 10:15 AM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
hey jerk, this is tech. Leave that other crap at home and don't try to be funny. If you don't have anything constructive to add here, pound sand.
Re: Do I need a new power steering box? [Re: sharpie] #504122
10/23/09 10:56 AM
10/23/09 10:56 AM
Az
Crizila Offline
Crizila  Offline
Az
If the overcenter adjustment has been made and all else is tight, the play is in the worm gear - time for a rebuilt box.
Fastest 300
Re: Do I need a new power steering box? [Re: Crizila] #504123
10/23/09 11:27 AM
10/23/09 11:27 AM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
That's what I figured, too. We've gone all the way from the loose end of the spectrum to the tight end with the only difference in the steering coming after the 15° window.
Re: Do I need a new power steering box? [Re: sharpie] #504124
10/23/09 11:49 AM
10/23/09 11:49 AM
Same thing I went through, with both the new and the old box.
If you do get a new one, post here and let me know how it works. I would LOVE to tighten the steering up.
Re: Do I need a new power steering box? [Re: hooziewhatsit] #504125
10/23/09 11:57 AM
10/23/09 11:57 AM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
Sounds good. I'm going to try the box out at the parts store and make sure that it doesn't have play before I even take it home.
Re: Do I need a new power steering box? [Re: sharpie] #504126
10/23/09 01:15 PM
10/23/09 01:15 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I think that is going to be tough to tell. You don't have the leverage of your steering wheel and the resistance your output shaft gets from the steering suspension.
Have you checked out other older mopar that had tighter steering? Your suspension linkage may show no obvious movement but a little in each part can ad up. It's really functionly fine, it just not going to feel like a new Mini Cooper.
What were your alignment specs? Those 70 series front tires aren't helping.
Re: Do I need a new power steering box? [Re: autoxcuda] #504127
10/23/09 01:51 PM
10/23/09 01:51 PM
hi
sharpie Offline OP
Moparts Linguist
sharpie  Offline OP
Moparts Linguist
hi
I know it won't feel like my MINI Cooper. I haven't ever felt the steering on another Mopar (never driven any other in my life), but it steers fine when it's past that 15° window. It's supple, moves me exactly where I want to go, and it rebounds just fine. However, it's that small window where it's bad. This is just annoying on the street, but on the highway it's downright scary. My car tends to float back and forth in its lane after 60MPH, which I realize is a suspension problem and will be fixed as soon as I make some $$, but my steering should be able to correct it for now, and it cannot because of that window of play.
The only thing that could be bad in the steering at this point are my idler arm and pitman arm or the LCA bushings. The TREs are all new, the ball joints are all new, and the UCAs are all new.
I don't know what the specs were on my alignment, but I had it aligned to stock.
But like I said, within this 15° window, we're talking it feels as if the shaft isn't connected to the box. Only when I get out of this window does it actually get some resistance on the wheel.
Re: Do I need a new power steering box? [Re: sharpie] #504128
10/23/09 05:50 PM
10/23/09 05:50 PM
Norway
General 68 Offline
General 68  Offline
Norway
Mine did the same thing. Got a Firm Feel stage 2. Big difference. No play and drives super straight!
Re: Do I need a new power steering box? [Re: General 68] #504129
10/23/09 07:26 PM
10/23/09 07:26 PM
minot north dakota
ledft79 Offline
ledft79  Offline
minot north dakota
Mine does it too, where do you get a firm feel 2, and what kind of $ do you need to spend. I have realy been considering to go to rack and pinion.
DRIVE EM, DONT HIDE EM.
Re: Do I need a new power steering box? [Re: General 68] #504130
10/24/09 02:10 AM
10/24/09 02:10 AM
Western Michigan
68Fastback Offline
68Fastback  Offline
Western Michigan
Best investment I ever made for steering on our cars, really gives you a better feel. Also I know you said you checked but on two of my cars the box was loose and gave me a similar feeling, so put a socket to them. If you decide to change the box let me know I will give you some tips.
Re: Do I need a new power steering box? [Re: ledft79] #504131
10/24/09 02:41 AM
10/24/09 02:41 AM
Shoreline, Washington
72roadrunnergtx Offline
where do you get a firm feel 2, and what kind of $ do you need to spend ?
www.firmfeel.com
Another satisfied Firm Feel customer here, stage 2.
1972 Road Runner GTX 440 6bbl 5-speed
[img]http://72rrgtx.com/carpics/bucket/DSC06730r-1.jpg[/img]
