Re: Early A Body, Radiator Upgrade?
[Re: tsdart]
#501219
10/19/09 04:55 PM
10/19/09 04:55 PM
Posts: 893 Tustin, CA
pishta
Tustin, CA
I used a stock 3 core radiator out of a Jeep Cherokee (round headlights) wall to wall radiator between the supports and I just had to braze on tabs to secure it to the frame rail. in and outs were the same size and I think I even used the same lower hose. Good enough for a 451.
12 Grand Caravan 06 T&C 02 T&C 96 Breeze 65 Barracuda "S"
[Re: tsdart]
#501221
10/21/09 09:02 PM
10/21/09 09:02 PM
Posts: 982 W. Sacto CA. USA
phantomx
W. Sacto CA. USA
When my brother put a 440 in his 64 Dart, he used a later rad from some mid 70s junk (Cordoba?). It was the right height, but quite a bit wider, he had to trim the inner flanges of the front rails to make it fit. It had 2 rows of wide tubes. That car would not overheat. We had a nice piece of road in front of our house where we did back to back 1/4 mile passes for about 20 minutes. The gauge never went above 180 I don't know if you want to modify your car any, but I thought I'd throw it out there. Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
[Re: tsdart]
#501222
10/22/09 09:20 AM
10/22/09 09:20 AM
Posts: 1,139 West Tennessee
rbstroker
West Tennessee
I had the small block radiator for my '65 Coronet recored and the lower tube moved slightly to the left for a big block. Before I had a chance to install it, I ended up with the proper 426 radiator for the Coronet. Long story/short, the radiator fit my small block '65 Dart like a glove. I used it for 3 months before going aluminum for the weight advantage (race only). Having said all of that, maybe you can find an early "B" body radiator easier than an "A" body one.
This is the land of the free
because of the brave
