Early A Body, Radiator Upgrade? #501217
10/19/09 03:05 PM
10/19/09 03:05 PM
Eastern Shore of MD
tsdart Offline OP
super gas
tsdart  Offline OP
super gas
Eastern Shore of MD
What's my options, I need to replace the radiator, it's done.
I still have the 273 in the car but the 340 is waiting in the wings.
What should I do to get back on the road?
recore my stock one?
go big money aluminum? (will it work with the 340)
Is there another option with a different stock radiator?
Re: Early A Body, Radiator Upgrade? [Re: tsdart] #501218
10/19/09 03:16 PM
10/19/09 03:16 PM
Is there another option?
www.speedwaymotors.com has some very reasonable aluminum radiators.
Re: Early A Body, Radiator Upgrade? [Re: tsdart] #501219
10/19/09 04:55 PM
10/19/09 04:55 PM
Tustin, CA
P
pishta Offline
pishta  Offline
P
Tustin, CA
I used a stock 3 core radiator out of a Jeep Cherokee (round headlights) wall to wall radiator between the supports and I just had to braze on tabs to secure it to the frame rail. in and outs were the same size and I think I even used the same lower hose. Good enough for a 451.
12 Grand Caravan
06 T&C
02 T&C
96 Breeze
65 Barracuda "S"
Re: Early A Body, Radiator Upgrade? [Re: pishta] #501220
10/21/09 06:13 AM
10/21/09 06:13 AM
Eastern Shore of MD
tsdart Offline OP
super gas
tsdart  Offline OP
super gas
Eastern Shore of MD
Anyone else?
Re: Early A Body, Radiator Upgrade? [Re: tsdart] #501221
10/21/09 09:02 PM
10/21/09 09:02 PM
W. Sacto CA. USA
P
phantomx Offline
phantomx  Offline
P
W. Sacto CA. USA
When my brother put a 440 in his 64 Dart, he used a later rad from some mid 70s junk (Cordoba?). It was the right height, but quite a bit wider, he had to trim the inner flanges of the front rails to make it fit. It had 2 rows of wide tubes. That car would not overheat. We had a nice piece of road in front of our house where we did back to back 1/4 mile passes for about 20 minutes. The gauge never went above 180 I don't know if you want to modify your car any, but I thought I'd throw it out there.
Travis..
70 GTX project, orig 440-4, 4 spd, track pack, FC7, stripper/street racer special.
Re: Early A Body, Radiator Upgrade? [Re: tsdart] #501222
10/22/09 09:20 AM
10/22/09 09:20 AM
West Tennessee
rbstroker Offline
rbstroker  Offline
West Tennessee
I had the small block radiator for my '65 Coronet recored and the lower tube moved slightly to the left for a big block. Before I had a chance to install it, I ended up with the proper 426 radiator for the Coronet. Long story/short, the radiator fit my small block '65 Dart like a glove. I used it for 3 months before going aluminum for the weight advantage (race only). Having said all of that, maybe you can find an early "B" body radiator easier than an "A" body one.
This is the land of the free because of the brave
