single stage paint #497252
10/14/09 06:51 PM
10/14/09 06:51 PM
chicago Burbs
demoned Offline OP
demoned  Offline OP
chicago Burbs
what is single stage paint going to paint my engine bay and the shop said this is what he will use he said there is no clear that is used with this process. Is this a good way of painting this it will be black. what do think is fair price for this .THKS ED
Re: single stage paint [Re: demoned] #497253
10/14/09 07:21 PM
10/14/09 07:21 PM
Michigan Troll
blk00rt Offline
blk00rt  Offline
Michigan Troll
what paint is he using? It will effect the price of the job. I believe the cheap stuff starts out around 50 a gallon and goes up from there depending on quality of paint.
Rob Dunn
1976 Dart Sport 360
2000 dakota RT 408 with 150 nitrous
2013 Dodge Ram 1500 Hemi
2009 Jeep Patriot
Re: single stage paint [Re: blk00rt] #497254
10/14/09 07:55 PM
10/14/09 07:55 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
I have heard many people using single stage on engine bay/trunk/door jams, etc. A good single stage will spray on smooth and that's it. Since you can't buff or polish an engine bay because of its shape, and because it's completely shielded from the sun you really lose nothing by using a single stage in those areas. You can get great gloss out of a single stage these days.
Re: single stage paint [Re: DaytonaTurbo] #497255
10/14/09 08:18 PM
10/14/09 08:18 PM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
It's been a few years...but
they do make a clear for single stage....... I used it several time..but it depends on the brand....
but why bother... times are a changing
Re: single stage paint [Re: 340dart4spd ] #497256
10/14/09 08:24 PM
10/14/09 08:24 PM
Q
quick77rt Offline
Parts Problem
quick77rt  Offline
Parts Problem
Q
As much as I could not beleive it myself, my brothers garage kept ride was painted a nice color of red about 10 years ago. It looks good today.
It turned out to be IH Red enamal straight from the farm store.
Re: single stage paint [Re: quick77rt ] #497257
10/14/09 09:57 PM
10/14/09 09:57 PM
Toronto, Canada
dirtybee Offline
dirtybee  Offline
Toronto, Canada
i painted my engine bay and floor pans inside and out as well as my front fenders with sherwin williams urethane enamel single stage paint 5-6 years ago and it still looks great. when i can afford to do my quarters i will use the same stuff, it looks great. not a show car but with some buffing and polish it prolly could be close.
Re: single stage paint [Re: demoned] #497258
10/14/09 10:11 PM
10/14/09 10:11 PM
SE Pa.
LimeliteAero Offline
SE Pa.
I dont know about price but the use of single stage paint in the engine compartment is highly accepted as normal.
Re: single stage paint [Re: LimeliteAero] #497259
10/14/09 10:46 PM
10/14/09 10:46 PM
scratchnfotraction Offline
check out pics of my 440 truck progress on the truck page
I used rustolium gloss black for the frame,under hood,underside of wheel wells, iside under hood,core support,door jambs, inside cab,rear 8 3/4 axle...
used a HVLP spray gun..my first paint job
results will vary
Re: single stage paint [Re: demoned] #497260
10/15/09 12:11 AM
10/15/09 12:11 AM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
Overall there is nothing wrong with single stage paint(providing it is quality paint were talking about). It's typically easy too apply, cheaper, & holds out well. In some aspects I prefer the look for a older car- I sprayed my Demon in Endura single stage as I felt it looked more "correct" not the super glossy forever wet look that some choose to have(not to say that single stage can't look like that with a little effort). That being said there is one aspect to consider in a engine bay and that is the effect that fluids may have on it if spilled/ spashed etc and not cleaned all the time. Depending on the color the paint may stain & discolor whereas if it is cleared it does offer some protection against possible color change. If you are for sure going black you don't have much to worry about
Re: single stage paint [Re: 72demon416] #497261
10/15/09 05:09 AM
10/15/09 05:09 AM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
All the single stage polyurethene paints I've used have 30-40% clear mixed into the paint itself. I have used it on many show cars and it's held up for years. I have even used it on complete cars and 5 years later it looks like it was just applied.
Re: single stage paint [Re: maximus] #497262
10/15/09 07:06 AM
10/15/09 07:06 AM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
PPG single stage here. I like it.
Stan
Re: single stage paint [Re: HemiStan] #497263
10/15/09 09:02 AM
10/15/09 09:02 AM
cmansell Offline
cmansell  Offline
Yes use single stage, it's what was there from the start.
Re: single stage paint [Re: cmansell] #497264
10/15/09 12:04 PM
10/15/09 12:04 PM
New Kent, Va.
bobbyb Offline
bobbyb  Offline
New Kent, Va.
I used single stage on my engine compartment and jams. Base and clear on the outside. If I had to do over I would go with just one type of paint on the whole car. Mine might be different because of the yellow color, but two different types of paint on my car didn't really match as well as I would like.
2004 Dodge Rumble Bee 5.7 Hemi
1969 Plymouth Roadrunner
Re: single stage paint [Re: bobbyb] #497265
10/15/09 01:17 PM
10/15/09 01:17 PM
Boise Idaho
Boise Chall Offline
Boise Chall  Offline
Boise Idaho
But mine matched perfectly I used single stage on engine compartment, inside of hood, Door jams, Trunk and inside of trunk lid and 2 stage on the outside I wet sanded the 2 stage smooth and polished it and it looks like a pro did it
Re: single stage paint [Re: Boise Chall] #497266
10/15/09 01:56 PM
10/15/09 01:56 PM
petaluma,ca. u.s.a.
west Offline
west  Offline
petaluma,ca. u.s.a.
I had my whole car painted with single stage paint,I haven't wet sanded anything.cheap with fair to good results.
paint on car is 6 years old and hood is 2 years old.
Re: single stage paint [Re: west] #497267
10/15/09 05:19 PM
10/15/09 05:19 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
I used Nason acrylic urethane on mine, sprayed it myself and was very happy with the quality.
Re: single stage paint [Re: T2R9] #497268
10/15/09 05:29 PM
10/15/09 05:29 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
Another shot without the engine. The new single stage paints are very good quality.
Re: single stage paint [Re: demoned] #497269
10/15/09 05:51 PM
10/15/09 05:51 PM
fresno ca
mikeysmopars Offline
fresno ca
One other thing to keep in mind is metallic or solid colers. Metallic colors can tend to die back as a single stage because of the aluminum as well as anything with pearls. Vitamin c orange has a small amount of pearls as well as Plum Crazy purple and I have had both them colors haze over a little as a single stage. Solid colors seem to be more wet and deep but dont last in the elements and washing. Best single stage out there is Imron 5000 but its not cheap.
Founder and CEO of the Central Valley Mopar Drag Pack
Re: single stage paint [Re: mikeysmopars] #497270
10/15/09 06:44 PM
10/15/09 06:44 PM
Middle of the mitten
69DodgeCharger Offline
What about spraying a Dupont Centari (metallic) and spraying clear over it after the last color coat flashes, is tacky? My buddy has done this several times now with solid colors and has had pretty good results. I was considering trying it with mine since I already have almost two gallons of Centari to work with.
Re: single stage paint [Re: 69DodgeCharger] #497271
10/16/09 01:51 AM
10/16/09 01:51 AM
Chicago Burbs
sthemi Offline
sthemi  Offline
Chicago Burbs
Here is what black PPG Concept (single stage)looks like...68 B body...
