Re: Need help w/this 340 combo
[Re: mrart01]
#496618
10/13/09 09:44 PM
10/13/09 09:44 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Can you post the whole time slip numbers... could be as simple as running out of fuel on top end BUT 117 falls in line for the 11.28... how many revs does he turn ![](/ubbthreads/images/graemlins/wave.gif)
[Re: goldmember]
#496621
10/13/09 11:49 PM
10/13/09 11:49 PM
Seems like you're running pretty good for that cubic inch and weight of car to me. But yea more info would help
[Re: meus31]
#496626
10/14/09 08:32 AM
10/14/09 08:32 AM
Posts: 4,991 new jersey usa
11secdart
new jersey usa
![](/ubbthreads/images/graemlins/iagree.gif) combo looks good but I think the 60ft should be lower: 1.48-1.52.
[Re: BobR]
#496630
10/14/09 11:11 AM
10/14/09 11:11 AM
Posts: 3,245 Between a rock & a hard place
cudadoug
That cam can be improved on a BUNCH.
That's for sure! If it were my car, (assuming a full time race car...no street time) the first place I'd go is with a modern roller. I could see 2-3 tenths there easily with the right stick. Next, fiddle with more gear and a converter that is RIGHT for the rest of the combo.
No reason why he couldn't see 10.70-80's from what he has done so far!
[Re: mrart01]
#496631
10/14/09 11:11 AM
10/14/09 11:11 AM
Posts: 1,613 Burlington,Ont.
77DragracerR/T
Burlington,Ont.
In comparison i have a 3420# race car/driver,with a 408,11.9 comp.,Eddy heads with clean up in bowls/ports/runners,590 cam straight up,1.5 rockers,super victor intake,750hp carb,TTI headers,timing 38*locked,hughes springs(1111),904 trans TCS 8" converter with 5400 flash,low gear set,4.30 gear and 30X9 hoosier's Ran a best so far of 10.97 with 1.47 60' I'd start by seeing if the car is spinning and how the suspension is working. My suspension is only stock leafs with a added leaf each side.
