Need help w/this 340 combo #496617
10/13/09 09:29 PM
10/13/09 09:29 PM
indiana
mrart01 Offline OP
mrart01  Offline OP
indiana
A friend of mine has a .040 over 340 .Best time was 11.28 @ 117 w/a 1.55 60ft.It has a 750 pro system carb,340 victor jr.,edelbrock heads (gasket matched,maybe a tad more)1.5 rockers 12:1comp,590 mopar cam installed at 103.5.The trans is a 727 w/a 4800 turbo action conv.,29.5 x 9 hoosier slicks 4.56 gears super stock springs (clamped).The car weighs 3350 w/driver.The ? is ,shouldn`t there b more E.T. here.?Where should we look for a quicker e.t. ,60 ft. and mph?Just seems like there are cars on here w/less doing better.Any help would b appreciated.Thanks in advance
Re: Need help w/this 340 combo [Re: mrart01] #496618
10/13/09 09:44 PM
10/13/09 09:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Can you post the whole time slip numbers... could
be as simple as running out of fuel on top end BUT
117 falls in line for the 11.28... how many revs does
he turn
Re: Need help w/this 340 combo [Re: mrart01] #496619
10/13/09 11:21 PM
10/13/09 11:21 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
Sounds pretty solid for a 340....
Re: Need help w/this 340 combo [Re: mrart01] #496620
10/13/09 11:24 PM
10/13/09 11:24 PM
Gainesville,FL
goldmember Offline
goldmember  Offline
Gainesville,FL
More rear gear,or shorter tire. 904 with 2.74 low gear set and 5500converter. Those are my guesses based on limited input.
Re: Need help w/this 340 combo [Re: goldmember] #496621
10/13/09 11:49 PM
10/13/09 11:49 PM
Seems like you're running pretty good for that cubic inch and weight of car to me. But yea more info would help
Re: Need help w/this 340 combo #496622
10/14/09 12:06 AM
10/14/09 12:06 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Seems very good for a stock stroke 340 at that weight. Most of the faster smallblocks are strokers. Ron
Re: Need help w/this 340 combo #496623
10/14/09 05:37 AM
10/14/09 05:37 AM
indiana
mrart01 Offline OP
mrart01  Offline OP
indiana
What kind of info do u need? I can post this evening,he's wanting to get in the 10's w/out pulling the motor. The trans , more head work or cam could b an option
Re: Need help w/this 340 combo [Re: mrart01] #496624
10/14/09 07:43 AM
10/14/09 07:43 AM
Thats running very well for a stock stroke 340..i would be very happy to be running those numbers with one
Re: Need help w/this 340 combo [Re: mrart01] #496625
10/14/09 08:15 AM
10/14/09 08:15 AM
utica ny
meus31 Offline
meus31  Offline
utica ny
ask your friend how much his car weights and a more modern profile camshaft would probably do some good .
Re: Need help w/this 340 combo [Re: meus31] #496626
10/14/09 08:32 AM
10/14/09 08:32 AM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
combo looks good but I think the 60ft should be lower: 1.48-1.52.
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: Need help w/this 340 combo [Re: 11secdart] #496627
10/14/09 09:41 AM
10/14/09 09:41 AM
indiana
mrart01 Offline OP
mrart01  Offline OP
indiana
What size carb r u runnig and r your heads done up?
Re: Need help w/this 340 combo [Re: mrart01] #496628
10/14/09 09:44 AM
10/14/09 09:44 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
That cam can be improved on a BUNCH.
Re: Need help w/this 340 combo [Re: BobR] #496629
10/14/09 10:31 AM
10/14/09 10:31 AM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
That seems good for whats in it, maybe max port on heads, solid roller cam if he wants to spend the $$$$$$$$
Re: Need help w/this 340 combo [Re: BobR] #496630
10/14/09 11:11 AM
10/14/09 11:11 AM
Between a rock & a hard place
cudadoug Offline
cudadoug  Offline
That's for sure! If it were my car, (assuming a full time race car...no street time) the first place I'd go is with a modern roller. I could see 2-3 tenths there easily with the right stick. Next, fiddle with more gear and a converter that is RIGHT for the rest of the combo.
No reason why he couldn't see 10.70-80's from what he has done so far!
Re: Need help w/this 340 combo [Re: mrart01] #496631
10/14/09 11:11 AM
10/14/09 11:11 AM
Burlington,Ont.
77DragracerR/T Offline
Burlington,Ont.
In comparison i have a 3420# race car/driver,with a 408,11.9 comp.,Eddy heads with clean up in bowls/ports/runners,590 cam straight up,1.5 rockers,super victor intake,750hp carb,TTI headers,timing 38*locked,hughes springs(1111),904 trans TCS 8" converter with 5400 flash,low gear set,4.30 gear and 30X9 hoosier's
Ran a best so far of 10.97 with 1.47 60'
I'd start by seeing if the car is spinning and how the suspension is working.
My suspension is only stock leafs with a added leaf each side.
77 Aspen R/T 60'@1.41 10.76 @ 123.26
http://www.youtube.com/watch?v=Eya3Ue8KoZk
Re: Need help w/this 340 combo [Re: goldmember] #496632
10/14/09 05:03 PM
10/14/09 05:03 PM
indiana
mrart01 Offline OP
mrart01  Offline OP
indiana
He was running 4.88 but ran in the high 30's low 40's so it likes the 4.56 I'll get more info as soon as I talk to him
Re: Need help w/this 340 combo [Re: mrart01] #496633
10/17/09 01:10 PM
10/17/09 01:10 PM
indiana
mrart01 Offline OP
mrart01  Offline OP
indiana
Ok,the timing is 38* ,the 60ft is 1.56 the 1/8 is 7.43 @95.74 and the 1/4 was 11.28 @117.17.....So i guess we`re gonna take some weight out and order a roller.The ? is where would we take some weight from and who would make a decent solid roller?
Re: Need help w/this 340 combo [Re: mrart01] #496634
10/17/09 01:16 PM
10/17/09 01:16 PM
SoCal
Brian Hafliger Offline
SoCal
You don't need a roller cam to help out...you need to get rid of that 590 cam. It's way too big for what your doing.
I'd recommend a quicker and smaller lobe and keep it FT.
Probably around 250-254@ .050 on a 106lca and advance it 4 degrees or so.
You should pick up a ton of launch TQ and still maintain peak HP.
Brian Hafliger
