10/13/09 06:37 PM
10/13/09 06:37 PM
Riverside R.I. U.S.A.
suit-case Offline OP
can external parts from a 400 low deck fit on a 440.intake,heeders,oil pan,distributer,brackets,and covers.
Re: 440/400 [Re: suit-case] #496410
10/13/09 06:44 PM
10/13/09 06:44 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
except the intake and dist..
I am truckless..
Re: 440/400 [Re: 340SHORTY] #496411
10/13/09 06:47 PM
10/13/09 06:47 PM
thanks for the info
Re: 440/400 [Re: suit-case] #496412
10/13/09 06:51 PM
10/13/09 06:51 PM
header flange/ports are the same but the heads are raised 3/4" up & outward at a 45 angle on a 440 compared to a 400 which could affect the fit of the rest of the header in a tight compartment. The slotted shaft in the 400 dist will be too short for the 440. Oil pan/valve covers the same & most if not all brackets are identical. The A/
C compressor is the same but I think some of the mounting brackets for it are different between a B and an RB.
Re: 440/400 [Re: 340SHORTY] #496413
10/13/09 06:51 PM
10/13/09 06:51 PM
intake depends on what heads you use. and the dizzy will fit
with and adapter to gain more valve cover clearance.
but this is being picky lol.
Re: 440/400 #496414
10/13/09 07:03 PM
10/13/09 07:03 PM
will the heads and intake from the 400 fit on the 440.
Re: 440/400 [Re: suit-case] #496415
10/13/09 07:06 PM
10/13/09 07:06 PM
heads yes intake no. EDIT pushrods different also
Re: 440/400 #496416
10/13/09 11:19 PM
10/13/09 11:19 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
that's assuming he is using stage 6 heads and wants to put a 440 intake on the 400/383 ... also ... your dist scenerio only works with 440 to 400/383 .
i'm being picky
Re: 440/400 [Re: JohnRR] #496417
10/13/09 11:27 PM
10/13/09 11:27 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
i'm being picky
The valley pan rails are shorter on the 400 too.
pick, pick.
Re: 440/400 [Re: RemCharger] #496418
10/13/09 11:44 PM
10/13/09 11:44 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
dizzy will fit
Yes you need a spacer to use a 440 distributor in a 400/383 but it has nothing to do with the clearance to valve cover. It has to do with the RB 440 having a higher deck height than the than the big blocks. The 383/400 distributor will not fit on a 440 because the shaft is not long enough to reach the intermediate shaft drive slot. The reason that th intakes won't fit is for the same reason, the higher deck the farther the heads are apart.
Yes there is a spacer that can be used on the RB distributor so that it can be used on the low deck BB engines
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: 440/400 [Re: MoparforLife] #496419
10/14/09 12:29 AM
10/14/09 12:29 AM
WOW! you guys sure put me in my place. adapter has everything to do with clearance,
since i run a HEI style dist cap on my RB distributer on my low deck 470.
wouldn't clear without the adapter. and that stage 6 head game on a low deck with
an RB manifold works just peachy. think I'll go pick some.
Re: 440/400 #496420
10/14/09 01:12 AM
10/14/09 01:12 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
When you get thru blowing your horn and patting yourself on the back go back and READ the original post , the guy is asking about putting 400 parts ON TO the 440 block , not the other way around .
Re: 440/400 [Re: JohnRR] #496421
10/14/09 08:07 AM
10/14/09 08:07 AM
Upper Midwest
Upper Midwest
evidnetly 2fast must be assuming that everybody uses the HEI type distributor. IN OEM or standard cap sizing distributors the only thing different is the that the shaft is longer on the 440 therefore the reason for using a spacer when using a RB distributor in a BB engine. They BB/RB use the same cap housing and cap diameters are the same as is vac advance system.
Re: 440/400 [Re: MoparforLife] #496422
10/14/09 12:04 PM
10/14/09 12:04 PM
"intake depends on what heads you use. and the dizzy will fit
but this is being picky lol."
notice the words in the bold text?
point being that all the parts are interchangable to some point if you really
get down to it. and yes I did get it backwards. my appologizes. carry on.
Re: 440/400 #496423
10/14/09 12:43 PM
10/14/09 12:43 PM
Upper Midwest
Upper Midwest
Hey sorry about my sarcasm,
we all get get things bass ackwards at times. wouldn't human if we didn't.
Re: 440/400 [Re: suit-case] #496424
10/14/09 12:54 PM
10/14/09 12:54 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
intake - no, headers - yes, oil pan - yes, distrib - no, bracets - yes, vavle cover - yes
Coming soon!!!!
