Re: 440/400
[Re: suit-case]
#496412
10/13/09 06:51 PM
10/13/09 06:51 PM
RapidRobert
header flange/ports are the same but the heads are raised 3/4" up & outward at a 45 angle on a 440 compared to a 400 which could affect the fit of the rest of the header in a tight compartment. The slotted shaft in the 400 dist will be too short for the 440. Oil pan/valve covers the same & most if not all brackets are identical. The A/ C compressor is the same but I think some of the mounting brackets for it are different between a B and an RB.
Re: 440/400
[Re: 340SHORTY]
#496413
10/13/09 06:51 PM
10/13/09 06:51 PM
except the intake and dist..
intake depends on what heads you use. and the dizzy will fit with and adapter to gain more valve cover clearance. but this is being picky lol.
Re: 440/400
[Re: suit-case]
#496415
10/13/09 07:06 PM
10/13/09 07:06 PM
RapidRobert
heads yes intake no. EDIT pushrods different also
Re: 440/400
#496416
10/13/09 11:19 PM
10/13/09 11:19 PM
Posts: 75,092 A Banana Republic near you.
JohnRR
that's assuming he is using stage 6 heads and wants to put a 440 intake on the 400/383 ... also ... your dist scenerio only works with 440 to 400/383 .
i'm being picky
Re: 440/400
[Re: JohnRR]
#496417
10/13/09 11:27 PM
10/13/09 11:27 PM
Posts: 2,825 Sk. Canada
RemCharger
Sk. Canada
i'm being picky
The valley pan rails are shorter on the 400 too. pick, pick.
Re: 440/400
[Re: MoparforLife]
#496419
10/14/09 12:29 AM
10/14/09 12:29 AM
WOW! you guys sure put me in my place. adapter has everything to do with clearance, since i run a HEI style dist cap on my RB distributer on my low deck 470. wouldn't clear without the adapter. and that stage 6 head game on a low deck with an RB manifold works just peachy. think I'll go pick some.
Re: 440/400
#496420
10/14/09 01:12 AM
10/14/09 01:12 AM
JohnRR
When you get thru blowing your horn and patting yourself on the back go back and READ the original post , the guy is asking about putting 400 parts ON TO the 440 block , not the other way around .
Re: 440/400
[Re: JohnRR]
#496421
10/14/09 08:07 AM
10/14/09 08:07 AM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
evidnetly 2fast must be assuming that everybody uses the HEI type distributor. IN OEM or standard cap sizing distributors the only thing different is the that the shaft is longer on the 440 therefore the reason for using a spacer when using a RB distributor in a BB engine. They BB/RB use the same cap housing and cap diameters are the same as is vac advance system.
Re: 440/400
[Re: MoparforLife]
#496422
10/14/09 12:04 PM
10/14/09 12:04 PM
"intake depends on what heads you use. and the dizzy will fit with and adapter to gain more valve cover clearance. but this is being picky lol."
notice the words in the bold text? point being that all the parts are interchangable to some point if you really get down to it. and yes I did get it backwards. my appologizes. carry on.
Re: 440/400
#496423
10/14/09 12:43 PM
10/14/09 12:43 PM
MoparforLife
Upper Midwest
Hey sorry about my sarcasm, we all get get things bass ackwards at times. wouldn't human if we didn't.
Re: 440/400
[Re: suit-case]
#496424
10/14/09 12:54 PM
10/14/09 12:54 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
can external parts from a 400 low deck fit on a 440.intake,heeders,oil pan,distributer,brackets,and covers.
intake - no, headers - yes, oil pan - yes, distrib - no, bracets - yes, vavle cover - yes
