Bench Racing Streetable Wax Wedge? #494098
10/11/09 02:45 PM
10/11/09 02:45 PM
Mid-Ohio
Bakaruda432 Offline OP
mopar addict
mopar addict
Mid-Ohio
In the 1960's the Max Wedge was HOT but too much to be trully streetable so I hear.
If I bought a 440 block had it bored.055 over, with forged 12.5:1 Flat Top Pistons, CNC ported Max Wedge size Stealth heads, A&A Max Wedge cross ram, twin 650 E-85 DP carbs,600+ Lift solid Roller cam, 7.1 forged rods/4.25 inch forged crank for a total of 511 CID vs the original 426 CID would this be a better street/strip engine?
What do ya'll think?
Re: Bench Racing Streetable Wax Wedge? [Re: Bakaruda432] #494099
10/11/09 03:11 PM
10/11/09 03:11 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Of course......They`re ALL streetable to a certain point.
Re: Bench Racing Streetable Wax Wedge? [Re: Thumperdart] #494100
10/11/09 03:13 PM
10/11/09 03:13 PM
Mira Loma, CA
69B3GT Offline
69B3GT  Offline
Mira Loma, CA
Anything is streetable if your willing to drive it...and pay for fuel
Re: Bench Racing Streetable Wax Wedge? [Re: Bakaruda432] #494101
10/11/09 03:22 PM
10/11/09 03:22 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
I dont know if "better"..i think it would sure be faster! Back in the day the 426 Max Wedge w/ 13 to 1 CR and .570 lift cam was rated at 425 HP but probably produced around 500 HP. By todays standards that is almost a "mild" street/strip motor! It just was'nt done back then and cars were suposed to drive on the high way
Re: Bench Racing Streetable Wax Wedge? [Re: Bakaruda432] #494102
10/11/09 03:41 PM
10/11/09 03:41 PM
Phoenix,Az.
hemicop Offline
hemicop  Offline
Phoenix,Az.
Better? Of course! Street/strip? Depends on what you wanna put up with. The 12.5:1 pistons automatically minimizes the "street" part--but who am I to talk? My motor's 13.5:1 & I 'm building a Chev with 14:1. I have no problem running racefuel in a week-end cruiser. The x-ram may be a little tough on the street, too as they're definitely not low RPM manifolds, but I love 'em, too. I say build it, tell everyone it's a 383 with an old x-ram & go win some $$$$$$$$$$$
Re: Bench Racing Streetable Wax Wedge? [Re: Bakaruda432] #494103
10/11/09 05:02 PM
10/11/09 05:02 PM
Eagleville Tn.
rtstreet Offline
rtstreet  Offline
Eagleville Tn.
for sure more h.p. maybe still more with less compression
Re: Bench Racing Streetable Wax Wedge? [Re: Bakaruda432] #494104
10/11/09 05:47 PM
10/11/09 05:47 PM
Don't use them tiny 650 DP carbs, way to small for a big motor 850 DP maybe or even larger 950HP custom carbs like Quickfuels As far as streetable mine is, it runs mid tens on pump gas, 518 C.I. low deck six pak, do you want to race
Re: Bench Racing Streetable Wax Wedge? [Re: Cab_Burge] #494105
10/11/09 06:15 PM
10/11/09 06:15 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
There are much more radical engines driving on the street nowadays then the Max Wedge engines that were stock.
And they had 2 versions of the 426 Max Wedge. One was 13.5 comp and the other was 11.0 as thats the one they figured people would drive on the street. Both were rated at 425 HP but like was said they made more like 500 HP. Oh and the cam was only .520 lift with about 308 advertised duration. In 64 they dropped the 13.5 eng to 12.5 as they found out it made the same HP. Ron
Re: Bench Racing Streetable Wax Wedge? [Re: 383man] #494106
10/11/09 07:56 PM
10/11/09 07:56 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
With enough gear, almost anything's streetable. Twin 650s may restrict the top end, but should have better throttle response on the street than a larger setup. Look at cams with fast ramps and healthy lift #s as opposed to long duration and lots of overlap.
Re: Bench Racing Streetable Wax Wedge? [Re: Bakaruda432] #494107
10/11/09 11:18 PM
10/11/09 11:18 PM
AndyF Offline
AndyF  Offline
The original 413 and 426 MW engines were a little high strung for street use but when you add a 4.25 inch stroke crank those things mellow out.
I had a 426 MW setup in my '65 Coronet when I was just out of high school. That was my daily driver back in the late 70's. With 4.56 rear gears it ran around town just fine but didn't do so well on the highway.
Re: Bench Racing Streetable Wax Wedge? [Re: AndyF] #494108
10/11/09 11:32 PM
10/11/09 11:32 PM
Arizona
Chris'sBarracuda Offline
Arizona
I had a 64 Plymouth Factory Aluminum front end car in high school (mid 70's).. Drove it every day to school and work..(Centerline Wheels)
Man that thing was raspy.. Had a ball with it..
All Stock down to the fuel system and ignition. Put 4.88"s in it with slicks, a good converter, and ran low 11's @ 121mph all day @ OCIR in So. Cal..
Held down in High School too..
I sure miss that car..
Chris..
Re: Bench Racing Streetable Wax Wedge? [Re: AndyF] #494109
10/11/09 11:40 PM
10/11/09 11:40 PM
Utah
topbrent Offline
topbrent  Offline
Utah
We built a pump gas, RB 505" Max Wedge street brawler recently.
620 HP @ 5900-rpm
621 TQ @ 4300-rpm
With that torque curve, it should be alot of fun!
- 4.25 crank,
- 7.1 rods
- 11.5 compression - Flat top pistons
- Edelbrock RPM Heads, Max Wedge ports, CNC by MCH
- Complete A&A Max Wedge top end, port matched
- Edelbrock 650 carbs
- Ultradyne 259/263 @.050 108lsa flat tappet
- Chenowith Girdle
- 2" TTI headers
Re: Bench Racing Streetable Wax Wedge? [Re: Bakaruda432] #494110
10/11/09 11:46 PM
10/11/09 11:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I would step up on the carbs.... remember that E-85
requires 30% more fuel than gas... a wider lobe separation
helps on the street(less pressure in the low rpm's)
but that should be very street-able, you might not
like the mpg
Re: Bench Racing Streetable Wax Wedge? [Re: MR_P_BODY] #494111
10/13/09 09:51 AM
10/13/09 09:51 AM
Mid-Ohio
mopar addict
mopar addict
Mid-Ohio
I thought E-85 would be a natural as Norwalk, OH. has 2 stations that sell it. It sells for $.30-.50 cheaper than 87 octane and it has an octane rating of 95-105 depending upon whether it is E-70, E-75, or E-85.
Thanks guys this seems like the combo for a "thristy" street cruiser/ weekend strip bruiser.
A 22 gal fuel cell + a 2 1/2-3 Gal "Moon" tank should at 4mph give an 88 mile range with an emergency reserve.
