Re: 1969 charger oil sending unit....
[Re: Rat_Exterminator]
#492837
10/10/09 10:35 AM
10/10/09 10:35 AM
Posts: 5,906 Athens, Greece
Pyper70
Athens, Greece
Mine runs close to 60 lbs when cold and 40 when warm. What unit do you have the Melling HV ?? Also depends on the type of oil you use. On my 70 440 I ran straight 50 and came out with 70 cold and 60 warm. While my 69 runs 20w50
Family owned 1969 Charger R/T DualQuad 440/727/GVO/3.55s
#492843
10/10/09 06:42 PM
10/10/09 06:42 PM
Posts: 25,200 Upper Midwest
MoparforLife
Upper Midwest
just got my 69 charger on the road, way low readings showed 10-20#, went thru dash, replaced voltage regulator, finally swapped out sending unit and went right to 40-60#. had wrong unit on, one meant for idiot light not gauge, that could be your problem too, similar symptoms. Greg
Guage takes a big bell shaped sender and lite is the little flat sender. Running a late model - Late model what: All the later small blocks the unit is in the same liocation in the top rear of the block next to the distributor..
