Page 1 of 3 1 2 3
8.75 or 9" Rear? #490476
10/07/09 09:23 AM
10/07/09 09:23 AM
NC
Badfish67 Offline OP
NC
My car is all Mopar and I hate the thought of putting a 9" rear in it, but i'm about to back half the Barracuda and everyone is telling me to go with a 9" rear. Can I hear from some of the back halfed guys that run sub 10's please.
1967 Barracuda 360ci/727 9.723ET @139.44mph
Re: 8.75 or 9" Rear? [Re: Badfish67] #490477
10/07/09 09:27 AM
10/07/09 09:27 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Nothing wrong w/ a 9". I'd think it'd be cheaper in the long run. If you have the 8.75 complete w/ gears and all use it. But if you are starting from scratch I'd go w/ a 9". You can oreder them in any lenght. I'm guessing you will backbrace either?
Coming soon!!!!
Re: 8.75 or 9" Rear? [Re: Badfish67] #490478
10/07/09 09:27 AM
10/07/09 09:27 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
No way I would consider a 8 3/4 on a back half car. Hook hard one time, and it will spit the ring gear, pinion gear, and main caps out in one shot. Don't waste your time with one.
Jeff
69 GTX 68 Road Runner
Re: 8.75 or 9" Rear? [Re: JERICOGTX] #490479
10/07/09 09:35 AM
10/07/09 09:35 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
Jeff
You might be right..lol My first all out pass in a mild 440 and 6psi of boost exploded the ring/pinion and caps into a thousand pieces. To the rears credit it was 30something uears old and had at least 200 runs on it.
Coming soon!!!!
Re: 8.75 or 9" Rear? [Re: Mr.Yuck] #490480
10/07/09 09:44 AM
10/07/09 09:44 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
With a 8 3/4 it's not a matter IF it will break, it's a matter of WHEN??? Why risk it. Install a 9" in it right from the start.
Jeff
Re: 8.75 or 9" Rear? [Re: Mr.Yuck] #490481
10/07/09 09:45 AM
10/07/09 09:45 AM
NC
NC
Yea, if I go with a 9" it will be a fabricated housing that my chassis guy builds. I'll be running some big tires and spraying some NOS too.
Re: 8.75 or 9" Rear? [Re: Badfish67] #490482
10/07/09 09:49 AM
10/07/09 09:49 AM
Orlando Florida
blown572dart Offline
Orlando Florida
9" just ask Tony (Quicktree)
Re: 8.75 or 9" Rear? [Re: Badfish67] #490483
10/07/09 09:52 AM
10/07/09 09:52 AM
an8sec70cuda Offline
Do not waste your time with the 8 3/4. Get a 9" and be done with it. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 8.75 or 9" Rear? [Re: an8sec70cuda] #490484
10/07/09 09:56 AM
10/07/09 09:56 AM
Left Coast
BobR Offline
BobR  Offline
Left Coast
8 3/4 rears are fine for stock eliminator and street guys but, really, most serious racers use some aftermarket version of the Ford 9"-and they do it for a reason.
Re: 8.75 or 9" Rear? [Re: Badfish67] #490485
10/07/09 10:15 AM
10/07/09 10:15 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Like I always say... weight is the killer... if you
believe the car will be light then the 8 3/4 will work
fine.... I've been running the 8 3/4 for YEARS... I did
break the first one after 600+ passes...
BUT my car is LIGHT... but I have had a best 60' of 1.19
with my lowly 8 3/4... now I run the alum center
for it... much stronger... the one I broke was completely
stock except for the 4.88 gear(the first 2 years it
had the stock cone style posi). If you think the car
will be heavy... go a different direction... JMO
Re: 8.75 or 9" Rear? [Re: MR_P_BODY] #490486
10/07/09 11:08 AM
10/07/09 11:08 AM
Y-town ohio
68valiant68 Offline
68valiant68  Offline
Y-town ohio
You do have one more option, put a dana 60 in it. For a mid 10 sec machine they are bulletproof and cheaper to build than a "good" 9" rear end.
Re: 8.75 or 9" Rear? [Re: 68valiant68] #490487
10/07/09 11:13 AM
10/07/09 11:13 AM
NC
NC
The Dana 60 is out because of the weight and changing gears are a pain in the butt. I race 1/8 and 1/4 so changing the 3rd member is no big deal on the 8.75 or 9".
Re: 8.75 or 9" Rear? [Re: Badfish67] #490488
10/07/09 11:21 AM
10/07/09 11:21 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
8 3/4`s rule.
Re: 8.75 or 9" Rear? [Re: Badfish67] #490489
10/07/09 11:42 AM
10/07/09 11:42 AM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
I don't find this a good argument against a D60. Most people don't have the extra coin to have 2 GOOD third members laying around. Seems like a good 9" center will be up around $1500?
Re: 8.75 or 9" Rear? [Re: Bigcube] #490490
10/07/09 12:17 PM
10/07/09 12:17 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Our Dewco was closer to 5000.
Re: 8.75 or 9" Rear? [Re: BobR] #490491
10/07/09 12:28 PM
10/07/09 12:28 PM
Plenty of guys running in the 9's with properly preped 8 3/4's..
Re: 8.75 or 9" Rear? [Re: Badfish67] #490492
10/07/09 12:33 PM
10/07/09 12:33 PM
Cab_Burge Online work
Cab_Burge  Online Work
A professionally prepared Dana 60 with chrome moly axle tubes will not be that much heavier than a comparable 9 inch(unless you use the aluminum center section on the 9 inch) and the Dana 60 does not have the frictional losses that the 9 inch has As far as gear changes for the 1/8 versus the 1/4 not many racers change the grear ratio that know of, just spray a little more on the line or ten feet out
Re: 8.75 or 9" Rear? [Re: Badfish67] #490493
10/07/09 02:14 PM
10/07/09 02:14 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
For the money, I recommend a Strange-60 assy.
This will cost less, and weigh virtually the same as a good drag style 9" rear. Stockish circle track type 9" rears may cost and weigh less, but these are not really any stronger than an 8 3/4".
If you must have a third-member and your car makes torque and hooks up hard, I recommend stepping up to a 9.5" (or larger) assembly. This is what the big boys run.
Re: 8.75 or 9" Rear? [Re: Badfish67] #490494
10/07/09 02:47 PM
10/07/09 02:47 PM
iowa
wesw Offline
wesw  Offline
iowa
if you want to be working on the rear diff all the time put that 8 3/4 in it. the 9" will last and take the abuse.
598 ci predator
Re: 8.75 or 9" Rear? [Re: wesw] #490495
10/07/09 03:44 PM
10/07/09 03:44 PM
Q
Quicktree Offline
Quicktree  Offline
Q
9" 9" 9" 9"
Page 1 of 3 1 2 3
