833 Tranny Capacity & Correct Oil? #486119
10/02/09 12:30 PM
10/02/09 12:30 PM
Indiana
Beastiedoggie Offline OP
Indiana
I live in NW INdiana ad don't drive the car at all in the winter. Can anyone recommend the best oil to use for the 833 manual trans? I'd also like to know how much to ut in. Thank u
beast
Re: 833 Tranny Capacity & Correct Oil? [Re: Beastiedoggie] #486120
10/02/09 12:33 PM
10/02/09 12:33 PM
Bellevue, WA
Blackwidow69 Offline
Ring Knocker
Ring Knocker
Bellevue, WA
Passon Performance makes the best fluid and I beleive it is 4 quarts.
1969 Ply Roadrunner, 383 4-speed on street tires. 3,830 lbs race weight. Best 1/4: 13.1 @ 106.83 440 & overdrive 4 speed going in. 2005 Power Wagon 35X12.5 KM2's
Re: 833 Tranny Capacity & Correct Oil? [Re: Beastiedoggie] #486121
10/02/09 12:34 PM
10/02/09 12:34 PM
Kirkland, Washington
Pacnorthcuda Online boogie
Pacnorthcuda  Online Boogie
Its slightly under 4 quarts. About 3.75.
Re: 833 Tranny Capacity & Correct Oil? [Re: Pacnorthcuda] #486122
10/02/09 12:40 PM
10/02/09 12:40 PM
Indiana
Indiana
Got it...any particular weight that works best for the 833? Should I shy away from synthetics?? I love using Royal Purple in almost all of my cars including my 2009 Ram. Is this a good idea?
beast
Re: 833 Tranny Capacity & Correct Oil? [Re: Beastiedoggie] #486123
10/02/09 12:43 PM
10/02/09 12:43 PM
Some people like synthetics in an 833 some don't. Redline is good.
1 BIG point!!!! Do NOT run a GL-5 in it. You need a GL-4 which can be difficult to find. (especially non-synthetic) THe GL-5's have extreme pressure additives (they're for rears) that are not friendly to your synchros.
75-90 works,
Re: 833 Tranny Capacity & Correct Oil? [Re: Pacnorthcuda] #486124
10/02/09 12:47 PM
10/02/09 12:47 PM
Indiana
Indiana
Thank u Pac....will look for it!!
beast
Re: 833 Tranny Capacity & Correct Oil? [Re: Blackwidow69] #486125
10/02/09 02:52 PM
10/02/09 02:52 PM
LEE, MASS
TOMRR Offline
TOMRR  Offline
LEE, MASS
Re: 833 Tranny Capacity & Correct Oil? [Re: TOMRR] #486126
10/02/09 05:05 PM
10/02/09 05:05 PM
Missouri
MY340 Offline
MY340  Offline
Missouri
75W-90 is a good choice and if you have an older tranny use 1 qt of Lucas oil additive. It helped quiet my 35 year old never been rebuilt tranny in my previous Duster 340-4spd car on WOT up shifts.
1970 FE5 Duster 360/904/3.91's SOLD 1973 TB3 SpaceDuster 340/4spd/4.10's SOLD Moparless for now but when the opportunity is right I'll have another one.
Re: 833 Tranny Capacity & Correct Oil? [Re: Beastiedoggie] #486127
10/02/09 08:06 PM
10/02/09 08:06 PM
Wisconsin USA
Bill MeLater Offline
Wisconsin USA
If you want it to shift at rpm just run atf in it.
Re: 833 Tranny Capacity & Correct Oil? [Re: Beastiedoggie] #486128
10/03/09 02:27 AM
10/03/09 02:27 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I have been using RedLine MTL (Manual Trans Lube) and I am happy with it. Check out RedLines web page for more info:
http://www.redlineoil.com/product.aspx?pid=45&pcid=7
Re: 833 Tranny Capacity & Correct Oil? [Re: 451Mopar] #486129
10/03/09 09:40 AM
10/03/09 09:40 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: 833 Tranny Capacity & Correct Oil? [Re: Rug_Trucker] #486130
10/03/09 12:40 PM
10/03/09 12:40 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
i use Passon's fluid, its good but thin and may result in more trans noise than a 80/90
Re: 833 Tranny Capacity & Correct Oil? [Re: ademon] #486131
10/03/09 04:38 PM
10/03/09 04:38 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I tried ATF and then Passion Lube in mine. Never did work right. Would grind going into the gears all the time with those two different lubes.
I put 85-140 in there and it works good. I was told my box wss junk on here before the 85-140 went in.
It certainly isn't cherry but it works good and hasn't had to be torn down yet. Had 102K on it when IO began this exercise and now has close to 108K after this summer with the heavy stuff.
I want my fair share
