833 Tranny Capacity & Correct Oil?
#486119
10/02/09 12:30 PM
10/02/09 12:30 PM
Posts: 298 Indiana
Beastiedoggie
Indiana
I live in NW INdiana ad don't drive the car at all in the winter. Can anyone recommend the best oil to use for the 833 manual trans? I'd also like to know how much to ut in. Thank u
beast
Re: 833 Tranny Capacity & Correct Oil?
[Re: Beastiedoggie]
#486120
10/02/09 12:33 PM
10/02/09 12:33 PM
Posts: 902 Bellevue, WA
Blackwidow69
Ring Knocker
Ring Knocker
Bellevue, WA
Passon Performance makes the best fluid and I beleive it is 4 quarts.
1969 Ply Roadrunner, 383 4-speed on street tires.
3,830 lbs race weight.
Best 1/4: 13.1 @ 106.83
440 & overdrive 4 speed going in.
2005 Power Wagon 35X12.5 KM2's
[Re: Pacnorthcuda]
#486122
10/02/09 12:40 PM
10/02/09 12:40 PM
Posts: 298 Indiana
Beastiedoggie
Indiana
Got it...any particular weight that works best for the 833? Should I shy away from synthetics?? I love using Royal Purple in almost all of my cars including my 2009 Ram. Is this a good idea?
beast
[Re: Pacnorthcuda]
#486124
10/02/09 12:47 PM
10/02/09 12:47 PM
Posts: 298 Indiana
Beastiedoggie
Indiana
Thank u Pac....will look for it!!
beast
[Re: Blackwidow69]
#486125
10/02/09 02:52 PM
10/02/09 02:52 PM
Posts: 1,013 LEE, MASS
TOMRR
LEE, MASS
[Re: TOMRR]
#486126
10/02/09 05:05 PM
10/02/09 05:05 PM
Posts: 5,270 Missouri
MY340
Missouri
75W-90 is a good choice and if you have an older tranny use 1 qt of Lucas oil additive. It helped quiet my 35 year old never been rebuilt tranny in my previous Duster 340-4spd car on WOT up shifts.
1970 FE5 Duster 360/904/3.91's SOLD
1973 TB3 SpaceDuster 340/4spd/4.10's SOLD
Moparless for now but when the opportunity is right I'll have another one.
[Re: ademon]
#486131
10/03/09 04:38 PM
10/03/09 04:38 PM
Posts: 10,201 Someplace you aren't
SomeCarGuy
I tried ATF and then Passion Lube in mine. Never did work right. Would grind going into the gears all the time with those two different lubes.
I put 85-140 in there and it works good. I was told my box wss junk on here before the 85-140 went in.
It certainly isn't cherry but it works good and hasn't had to be torn down yet. Had 102K on it when IO began this exercise and now has close to 108K after this summer with the heavy stuff.
I want my fair share
