1973 Charger Addco Rear Sway Bar Help #483647
09/29/09 05:30 PM
09/29/09 05:30 PM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
I am installing an addco rear sway bar in my 73 Charger and it doesn't fit right with the provided hardware. I have the wheels off and jack stands under the axle at normal ride height. My problem is that the middle links do not meet up to the frame, they are too far away and if I raise it to get close enough the end links hit the axle. Has anybody else installed one of these. This will be the last Addco product I ever buy I had a similar problem with their front sway bar.
Pictures
This is with the shorter bolts they supply, I can't even get it close to the frame
This is with the longer bolts and spacer, I cant even get all the bushings in because the bar hits the frame and rearend.
Re: 1973 Charger Addco Rear Sway Bar Help [Re: bordin34] #483648
09/29/09 10:13 PM
09/29/09 10:13 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Allmost all the aftermarket rear sway bars, not just Addco are pretty much the same, the mounting systems supplied suck!,....I've done a few, best advice is to mock up the rear bar on the frame rails, make new plates to relocate the threaded rod ends, or remove the axle shock plates and weld permanate plate extentions (beefed up), custom length bushing end rods/struts are avaliable at most AZ, or CarQuest, Advance, Napa stores, they can be purchased individualy
The Hellwig bar that bolts on to the rear axle, and has the rod ends mounted on the frame is a much better choice, incase you decide to change out the Addco bar
Mike
Re: 1973 Charger Addco Rear Sway Bar Help [Re: DAYCLONA] #483649
09/30/09 04:56 AM
09/30/09 04:56 AM
Berlin, Germany
Flo Offline
Flo  Offline
Berlin, Germany
stupid question, I am also considering adding Addco to my Fury. Do I have to weld on the axle? Where do they mount to?
Greets
Flo
1967 Fury III 4door HT tiny 318, late model roller block, bored and stroked to 344
Re: 1973 Charger Addco Rear Sway Bar Help [Re: Flo] #483650
09/30/09 05:21 AM
09/30/09 05:21 AM
rochester,new york
P
plumebody Offline
plumebody  Offline
P
rochester,new york
Firmfeel bars are much better fitting.
Re: 1973 Charger Addco Rear Sway Bar Help [Re: plumebody] #483651
09/30/09 06:36 AM
09/30/09 06:36 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
FF fit like stock bars do. I have FF on my 71 and Addco on my 74. I installed the Addcos like 15 years ago, I'd have to look and see how I did it, I know I had to modifiey something.
Re: 1973 Charger Addco Rear Sway Bar Help [Re: bordin34] #483652
09/30/09 07:54 AM
09/30/09 07:54 AM
Cincinnati, Ohio
Cincinnati, Ohio
My Addco bar is mounted backwards from the way you show yours. The bar is under the rear end and the end links attach to the frame. You can see it in this picture.
Re: 1973 Charger Addco Rear Sway Bar Help [Re: Challenger 1] #483653
09/30/09 08:24 AM
09/30/09 08:24 AM
Arlington, Texas
bobby66 Offline
bobby66  Offline
Arlington, Texas
Are you sure you have the right kit? Those isolated spring mounts are different from earlier B-bodies.
Re: 1973 Charger Addco Rear Sway Bar Help [Re: bobby66] #483654
09/30/09 02:04 PM
09/30/09 02:04 PM
Urbana, MD
bordin34 Offline OP
bordin34  Offline OP
Urbana, MD
I am pretty sure I have the right kit. It said in the instructions if I have the isolated type to use the shorter supplied bolts without the spacer. I think what I am going to do is cut the sleeve from the long bolt and buy shorter bolts.
