727 help needed
#483543
09/29/09 03:25 PM
09/29/09 03:25 PM
Posts: 74 West Tn
Skunk22
West Tn
I have a 69 SuperBee with a 440 mildly built with a 727 trans. As soon as I put it into drive , 2nd or low it starts to slide the front tires. I cannot hold the rear tires to keep them from pushing. I have a CR21 stall converter and acording to Torqueflite Patty it should be a 2800 to 3000 stall. I am only at 750 to 800 idle speed and it is pushing. What could the problem be? It has been doing this ever since it was built. Could the Reverse / Low band be to tight? Thanks David
Skunk's Den
1964 Impala Conv.
1966 Vette 427
1969 Super Bee
2005 Mustang
Re: 727 help needed
[Re: MoparforLife]
#483546
09/29/09 04:01 PM
09/29/09 04:01 PM
Posts: 74 West Tn
Skunk22
West Tn
Stumpy: Yes the rear brakes are working Tested that also. Mopar:Yes I had to pull the converter up to the flex plate to get it bolted in. I also spun it around before bolting it up just to make sure there was nothing in a bind. Thanks David
Skunk's Den
1964 Impala Conv.
1966 Vette 427
1969 Super Bee
2005 Mustang
Re: 727 help needed
[Re: Skunk22]
#483547
09/29/09 04:17 PM
09/29/09 04:17 PM
Posts: 26,017 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Ordinarily I would say that the problem is in the converter, a failed stator clutch would result in reduced stall speed but this usually kills the motor as soon as it's put in gear.
Sounds like you have two problems, a faulty converter and faulty brakes.
Re: 727 help needed
[Re: John_Kunkel]
#483548
09/29/09 04:26 PM
09/29/09 04:26 PM
Posts: 74 West Tn
Skunk22
West Tn
John: That was happening at first and I just brushed it of as a new tight converter. I did loosen some up after a few days but not enough. David
Skunk's Den
1964 Impala Conv.
1966 Vette 427
1969 Super Bee
2005 Mustang
Re: 727 help needed
[Re: Skunk22]
#483549
09/29/09 11:39 PM
09/29/09 11:39 PM
Posts: 2,006 s. e. pa.
calrobb2000
s. e. pa.
hi cr21 = cast crank hi stall. low band not applied in drive , so it is not the band . best guess = bad convertor ! ![](/ubbthreads/images/graemlins/hammer.gif)
Re: 727 help needed
[Re: calrobb2000]
#483550
10/02/09 04:42 PM
10/02/09 04:42 PM
Posts: 74 West Tn
Skunk22
West Tn
Well I was going to find the problem one way or the other so I droped it into low and hit it WOT. Heard something pop and then had no reverse. Pulled the trans which was a lot of fun with full length headers and opened it up to find a broken low reverse band. I had the converter tested and there was little to no clutch slipage at all. So now I get to rebuild the trans again and get a good converter with a 26-3000 stall. Any recomendations on the converter? Skunk
Skunk's Den
1964 Impala Conv.
1966 Vette 427
1969 Super Bee
2005 Mustang
