Re: Kickdown help
[Re: paulgrr63]
#483512
09/29/09 03:11 PM
09/29/09 03:11 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
your carb linkage is in a different position from the 2 bbl. You might need to modify or get another piece, it will need to be longer. I used one from a 6 cyl. but others have just modified the origanal piece. I am sure others will chime in with many ways to remedy this. This linkage controls the line pressure in the tranny. The main thing is to get it right or the transmission will burn out. ![](/ubbthreads/images/graemlins/crazy.gif) Ask me how I know?
Re: Kickdown help
[Re: paulgrr63]
#483513
09/29/09 03:13 PM
09/29/09 03:13 PM
Posts: 3,910 Oregon
hooziewhatsit
I did the same thing (4bbl/dual plane intake). On mine, I had to lengthen the rod that goes to the throttle.
Basically, you want it so at WOT, the kickdown/Throttle position rod is almost all the way back (saw ~1/16" play here somewhere).
Then adjust it forward/back to get the shifts where you like them.
