Page 2 of 3 1 2 3
Re: 727 front drum [Re: JohnRR] #482221
09/28/09 11:46 PM
09/28/09 11:46 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
both the TCS and the A+A have their pros and cons , I've had both ,Ii like the TCS because you can fit 5 thick clutches in it because the snap ring groove is higher BUT they put the vent valve in the WRONG place and kolene steels won't fit because the grooves for the steels are a little narrow , I have an EARLY TCS drum.
my TCS drum is just over a year old & my trans man managed to fit 6 kolenes into this drum. do you think they may have upgraded from your earlier version?
Re: 727 front drum [Re: rebel] #482222
09/29/09 09:17 AM
09/29/09 09:17 AM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
I talked to someone in the know and he had addressed the issues that my drum has with them and it seemed to be hit and miss as to whether it came in correct or not still. In their defense the drum I have is probably 6 or 7 years old , it was one of their first and I got it for half of what they sell for now. I'll move the vent and you can grind the edges of the kolene steels to make them fit properly. But if I were starting from scratch I'd pony up for the A+A .
Re: 727 front drum [Re: DJVCuda] #482223
09/29/09 09:35 AM
09/29/09 09:35 AM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
this is about 50 runs on an aluminum drum
use a billet steel one from CRT , of you plan on driving it on the street... - John is a great guy to deal with.
I think this picture and testimony is an example of not knowing
what you're looking at. OEM transmissions produce the same residue,
in complete passenger car applications.
I have/had an A&A aluminum drum in my 727 with way more than 50
passes on it and it has never looked like that.
Both drums have their place but, both solve the safety issues of
the OEM forged powder drum.
I hate for one guy's opinion to mislead potential customers for
the aluminum drum. It's not usually necessary but, is not the
cause for the grey sludge pictured.
Re: 727 front drum [Re: S/ST 3040] #482224
09/29/09 07:38 PM
09/29/09 07:38 PM
B.C.
mk_ Offline
mk_  Offline
B.C.
The A&A aluminum drum in my car has hundreds of passes on it and looks like it's hardly been used when I take it apart to check things over in the off season.
I change the trans fluid every 40 runs with Dextron 3 and don't ever have the sludge shown in the picture above.
I run a smooth red band from A&A as well and run a Tranzact valve body with a clean 2-3 shift which may help prevent premature drum wear.
Re: 727 front drum [Re: mk_] #482225
09/30/09 06:52 AM
09/30/09 06:52 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
and what do you think the silver material on those fingers is? swiss cheese?
it wear from the aluminum drum - plain and simple... i'm not bashing the aluminum drum... if you read my post it states that for a a car that drives on the street you will have to deal with this - that is a fact and that will not change.
this was not form an old tranny - it was a seasonal rebuild and the drum had wear at the band location.
here is that drum before it was cut.
Re: 727 front drum [Re: DJVCuda] #482226
09/30/09 08:39 AM
09/30/09 08:39 AM
U.S.S.A.
U.S.S.A.
Dave , what is this person using for a band ?
Re: 727 front drum [Re: JohnRR] #482227
09/30/09 08:40 AM
09/30/09 08:40 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
IIRC it was the either a red band or the factory blue, I know it was not the kevlar band - this pic was taken over 2 years ago - so it's escaping me right now..
I do know the fluid was changed every 50-75 runs and the drum was serviced every few seasons. This drum had at least 2 seasons ( 6-800 passes) when it was tore down. It needed to be cut after that.
Re: 727 front drum [Re: DJVCuda] #482228
09/30/09 08:44 AM
09/30/09 08:44 AM
U.S.S.A.
U.S.S.A.
I've never seen a blue band from the factory , but that's not saying they aren't ? either Raybestoes or Borg Warner sold a Blue Plate HP kit for race trans , I had one can't remember if the band was blue but I do know it was kevlar.
Re: 727 front drum [Re: JohnRR] #482229
09/30/09 08:45 AM
09/30/09 08:45 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
I think Mopar sells the blue ones.
Re: 727 front drum [Re: DJVCuda] #482230
09/30/09 09:42 AM
09/30/09 09:42 AM
S/ST 3040 Offline
S/ST 3040  Offline
I can't make out any aluminum in you first picture.
You said 50 runs on it. That's a lot of crap in there for 50 runs.
I wouldn't put aluminum drum in a car that saw street duty either.
It looks like BAD Swiss cheese.
edit: I'd expect the wear pictured on the drum after 600 passes.
Re: 727 front drum [Re: LA360] #482231
09/30/09 09:48 AM
09/30/09 09:48 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
If you buy anyone's Aluminium Drum, make sure you run a Red lined band. The Kevlar bands are too aggressive and will wear the drum out quickly.
AL....
thats what i use.Red band
I got my drum from JPT, he makes them in house,on his own CNC equipment. i think he said he was the first one to do that.
Have had mine over 5 years and still looks great..
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: 727 front drum [Re: S/ST 3040] #482232
09/30/09 10:10 AM
09/30/09 10:10 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
the picture of the drum was in fact 6-800 passes...
my last posts has that info in there..
Re: 727 front drum [Re: DJVCuda] #482233
10/01/09 07:48 AM
10/01/09 07:48 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I don't understand the infatuation with an aluminum drum. People have compared lightened drivetrain componets, and don't report much if any gain. Go with the billet steel unit, and be done with it.
Re: 727 front drum [Re: Leigh] #482234
10/01/09 09:24 PM
10/01/09 09:24 PM
High Ridge MO.
MOPARCHAS Offline OP
High Ridge MO.
what do you guys think about the full metal jacket aluminum steel sleeved drum from TCS
Re: 727 front drum [Re: MOPARCHAS] #482235
10/01/09 09:31 PM
10/01/09 09:31 PM
S/ST 3040 Offline
S/ST 3040  Offline
If it's a drag only car, get the aluminum or billet steel. If it
will see any street duty, get the billet steel.
If it's a small block, get a 904.
Re: 727 front drum [Re: S/ST 3040] #482236
10/01/09 11:01 PM
10/01/09 11:01 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
i had the same sludge in the bottom of my pan on the last refreshening and i dont have an aluminum drum. i figured it was from the kolenes.
Re: 727 front drum [Re: mopar dave] #482237
10/02/09 09:27 AM
10/02/09 09:27 AM
Newark, OH
Hunted Duck Offline
Hunted Duck  Offline
Newark, OH
Does anybody make the billet steel drum for a 904?
Re: 727 front drum [Re: Hunted Duck] #482238
10/02/09 09:55 AM
10/02/09 09:55 AM
S/ST 3040 Offline
S/ST 3040  Offline
TCS
I personally wouldn't bother unless, I was 100% sure I needed the
extra clamping of the bigger piston.
I'm using an OEM front drum on my first 904, due to lack of funds.
The next one will be aluminum. 904 drums don't have the front
drum explosions the 727s do, as their mass and diameter are
much less.
727 high gear drum is 3480.5 grams and 7.496" in diameter
904 high gear drum is 2378 grams and 5.876" in diameter
This example shows the 904 drum is 2.43 lbs. lighter and 1.620" less in diameter.
Re: 727 front drum [Re: S/ST 3040] #482239
10/02/09 10:29 AM
10/02/09 10:29 AM
Newark, OH
Hunted Duck Offline
Hunted Duck  Offline
Newark, OH
Thanks Vic. I am currently running a 727 but I am considering going back to a 904. I was wondering if that was a must going to the aftermarket drum.
Re: 727 front drum [Re: Hunted Duck] #482240
10/02/09 10:55 AM
10/02/09 10:55 AM
S/ST 3040 Offline
S/ST 3040  Offline
Get a 71-up 904 case. They have the bigger diameter servos.
Pre-68 have the wrong input spline count for RACE converters.
I think........76 and later 904s have the steel planetaries for
the 2.45:1 1st gear or get a 2.74:1 1st gear-set and swap.
Valve body from 727 is the same.
Multiple return-spring conversion for high gear drum is a must.
Longer driveshaft is required due to the 904s 3.900" shorter OAL.
1350 slip shafts are made by a few.
I'm no 727/904 specialist but, these are a few things I've found during my switch.
I hope it helps a little.
Page 2 of 3 1 2 3
