Header gaskets? Which ones are the best #482038
09/27/09 11:02 PM
09/27/09 11:02 PM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
I was wondering what do people like in the way of header gaskets for a 440 engine. I just went through a set of felpro's and am just wondering if people have a brand they like and trickd to keep from vlowing them?
Mike
1969 Dodge Dart Swinger
Re: Header gaskets? Which ones are the best [Re: MikeyT] #482039
09/27/09 11:04 PM
09/27/09 11:04 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
permatex ultra grey .............no gaskets !!
1.39 9.85 - 137 mph
Re: Header gaskets? Which ones are the best [Re: Ari440] #482040
09/27/09 11:09 PM
09/27/09 11:09 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
any brand of gasket that matches your ports, coated with silicon sealer & allowed to dry overnight will be a winner. the silicon makes them seal any old rusty header flange without blowing & be reusable multiple times.
Re: Header gaskets? Which ones are the best [Re: Ari440] #482041
09/27/09 11:57 PM
09/27/09 11:57 PM
land of 10,000______'s
BDS871Cuda Offline
BDS871Cuda  Offline
We use Hooker with ultra copper, let it set up for
about 25 minutes. ARP header bolts. Never had a
leak and never had a bolt come loose.
Snap your neck, mega G-force launch, is all I want!
Re: Header gaskets? Which ones are the best [Re: BDS871Cuda] #482042
09/28/09 07:19 AM
09/28/09 07:19 AM
Southern Utah
440Laser Offline
super street
440Laser  Offline
super street
Southern Utah
I've had great luck luck with Percey's. They are reuseable too.
Re: Header gaskets? Which ones are the best [Re: MikeyT] #482043
09/28/09 08:41 AM
09/28/09 08:41 AM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
I've been using the SCE copper gaskets.I've swapped them between 3 engines and they have sealed every time.
Nautilus Racing-
Re: Header gaskets? Which ones are the best [Re: Chris2581] #482044
09/28/09 09:39 AM
09/28/09 09:39 AM
OH--IO
3
360904 Offline
360904  Offline
OH--IO
Has anybody ever tried REMFLEX ?
Re: Header gaskets? Which ones are the best [Re: 360904] #482045
09/28/09 09:42 AM
09/28/09 09:42 AM
Atco NJ
DJVCuda Offline
DJVCuda  Offline
Atco NJ
Yes!
once you use them you wont go back to anything else... best gaskets I have ever used...
no more double gaskets, no voo doo to get them to seal, no re torquing, no problems!
we use the same gasket material in industrial piping that I work in and its a good design for exhaust...
Re: Header gaskets? Which ones are the best [Re: DJVCuda] #482046
09/28/09 09:48 AM
09/28/09 09:48 AM
OH--IO
3
360904 Offline
360904  Offline
OH--IO
Thanks, I think Remflex is what I am going to try
Re: Header gaskets? Which ones are the best [Re: 440Laser] #482047
09/28/09 09:51 AM
09/28/09 09:51 AM
North Riverside IL & Lowell IN
GTXKen Offline
super gas
GTXKen  Offline
super gas
I ran Percey's on my last two motors and really liked them, about $35 if I remember correctly, no leaking, no retorquing
Re: Header gaskets? Which ones are the best [Re: GTXKen] #482048
09/28/09 10:04 AM
09/28/09 10:04 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
I have never had any issues with Fel-Pros, even re-using them in a pinch.
Re: Header gaskets? Which ones are the best [Re: justinp61] #482049
09/28/09 02:50 PM
09/28/09 02:50 PM
Sk. Canada
RemCharger Offline
RemCharger  Offline
Sk. Canada
White cheap MR Gaskets.
I find the more expensive they are , the worse they work.
Re: Header gaskets? Which ones are the best [Re: RemCharger] #482050
09/28/09 02:55 PM
09/28/09 02:55 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Mr Gasket Ultra seals.They work and arent bad at like 16 bucks.Ive even reused them.Last set was on 6 years till I put the new heads on and I probally still could have reused them.I had the coppers on my 440 with TTIs and they leaked like there were no gaskets there.Rocky
Chrysler Firepower
Re: Header gaskets? Which ones are the best [Re: therocks] #482051
09/28/09 03:03 PM
09/28/09 03:03 PM
Nebraska
70VcodeCoronetRT Offline
Nebraska
X2 on the Mr. Gasket Ultra seals. Never had a leak with them yet.
Re: Header gaskets? Which ones are the best [Re: therocks] #482052
09/28/09 03:06 PM
09/28/09 03:06 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
I use the white paper gaskets. Been on the same set for a long time now with no issues.
A good seal is all about getting the header sealing surface straight and true. My hooker headers have a welded bead at each port and I took a marker and colored each bead and then took a wide fine tooth file and carefully worked each opening in a criss-cross pattern until the marker was gone and everything was nice and level.
I have used copper rtv in the past, but I don't have any in there right now. Keep an eye on the bolts after installing as they will loosen up a few times.
Re: Header gaskets? Which ones are the best [Re: DJVCuda] #482053
09/28/09 10:06 PM
09/28/09 10:06 PM
Greenville, WI
Big B Offline
Big B  Offline
Greenville, WI
Yes!
That's what I use too. Just be very careful putting them on. They break very easily.
Re: Header gaskets? Which ones are the best [Re: Big B] #482054
09/28/09 10:37 PM
09/28/09 10:37 PM
fullmetaljacket Offline
Percy's carbon felt-aluminum impregnated gaskets. Sealed my leaking noise from the exhaust Dam.
Re: Header gaskets? Which ones are the best [Re: fullmetaljacket] #482055
09/28/09 10:56 PM
09/28/09 10:56 PM
WA 98043
thecarfarmer Offline
WA 98043
I don't use the gaskets made for headers.
Like the previous poster, I make sure that the headers don't have a crappy bead of weld that's not flat.
Then I put on standard exhaust manifold gaskets, with a bit of anti-sieze.
I've even re-used 'em occasionally.
Seems to work for me; like I said above, it's probably just that I've never been told why it won't work, so it does.
BTW, I've had problems with header gaskets blowing out, even with filing the flanges.
-Bill
Seduce the attractive, and charm the rest. ****** 489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
Re: Header gaskets? Which ones are the best [Re: MikeyT] #482056
09/29/09 12:05 AM
09/29/09 12:05 AM
MR_P_BODY Offline
MR_P_BODY  Offline
You want a gasket that can slide... with the heat those
pipes grow a fair amount then it cools down... I make
my own gasket most of the time... I use a product called
Grafoil... stainless steel with graphite layers on
both sides
Re: Header gaskets? Which ones are the best [Re: MR_P_BODY] #482057
09/29/09 12:41 AM
09/29/09 12:41 AM
Watertown, WI
MikeyT Offline OP
MikeyT  Offline OP
Watertown, WI
Thanks guys. I think I'm going to give Percy's shot.
Mike
