Header gaskets? Which ones are the best
#482038
09/27/09 11:02 PM
09/27/09 11:02 PM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
I was wondering what do people like in the way of header gaskets for a 440 engine. I just went through a set of felpro's and am just wondering if people have a brand they like and trickd to keep from vlowing them?
Mike
1969 Dodge Dart Swinger
Re: Header gaskets? Which ones are the best
[Re: MikeyT]
#482039
09/27/09 11:04 PM
09/27/09 11:04 PM
Posts: 5,620 long island NY
Ari440
long island NY
permatex ultra grey .............no gaskets !!
1.39 9.85 - 137 mph
[Re: Ari440]
#482041
09/27/09 11:57 PM
09/27/09 11:57 PM
Posts: 1,949 land of 10,000______'s
BDS871Cuda
We use Hooker with ultra copper, let it set up for about 25 minutes. ARP header bolts. Never had a leak and never had a bolt come loose.
Snap your neck, mega G-force launch, is all I want!
[Re: 360904]
#482045
09/28/09 09:42 AM
09/28/09 09:42 AM
Posts: 11,179 Atco NJ
DJVCuda
Atco NJ
Has anybody ever tried REMFLEX ?
Yes!
once you use them you wont go back to anything else... best gaskets I have ever used...
no more double gaskets, no voo doo to get them to seal, no re torquing, no problems!
we use the same gasket material in industrial piping that I work in and its a good design for exhaust...
[Re: 440Laser]
#482047
09/28/09 09:51 AM
09/28/09 09:51 AM
Posts: 3,968 North Riverside IL & Lowell IN
GTXKen
super gas
super gas
I've had great luck luck with Percey's. They are reuseable too.
I ran Percey's on my last two motors and really liked them, about $35 if I remember correctly, no leaking, no retorquing
[Re: RemCharger]
#482050
09/28/09 02:55 PM
09/28/09 02:55 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
Mr Gasket Ultra seals.They work and arent bad at like 16 bucks.Ive even reused them.Last set was on 6 years till I put the new heads on and I probally still could have reused them.I had the coppers on my 440 with TTIs and they leaked like there were no gaskets there.Rocky
Chrysler Firepower
[Re: DJVCuda]
#482053
09/28/09 10:06 PM
09/28/09 10:06 PM
Posts: 325 Greenville, WI
Big B
Greenville, WI
Yes!
That's what I use too. Just be very careful putting them on. They break very easily.
[Re: fullmetaljacket]
#482055
09/28/09 10:56 PM
09/28/09 10:56 PM
Posts: 871 WA 98043
thecarfarmer
WA 98043
I don't use the gaskets made for headers. Like the previous poster, I make sure that the headers don't have a crappy bead of weld that's not flat. Then I put on standard exhaust manifold gaskets, with a bit of anti-sieze. I've even re-used 'em occasionally. Seems to work for me; like I said above, it's probably just that I've never been told why it won't work, so it does. BTW, I've had problems with header gaskets blowing out, even with filing the flanges. -Bill
Seduce the attractive, and charm the rest.
489 C.I.D., roller cam, aftermarket heads, tunnel ram, stock '54 Dodge rear axle assembly: which of these doesn't belong?
[Re: MikeyT]
#482056
09/29/09 12:05 AM
09/29/09 12:05 AM
Posts: 52,972 Romeo MI
MR_P_BODY
You want a gasket that can slide... with the heat those pipes grow a fair amount then it cools down... I make my own gasket most of the time... I use a product called Grafoil... stainless steel with graphite layers on both sides
[Re: MR_P_BODY]
#482057
09/29/09 12:41 AM
09/29/09 12:41 AM
MikeyT
Watertown, WI
Thanks guys. I think I'm going to give Percy's shot.
Mike
