Re: Max Wedge valve adjustment
[Re: slantman]
#478124
09/24/09 11:09 AM
09/24/09 11:09 AM
Posts: 43,161 Bend,OR USA
Cab_Burge
It depends on which valve covers you use, I had a original 415 HP 1963 M.W. Belvedere that was stock when I bought it. The stock valve covers where hard to get off at first until I learned to slide them around while lifting them up. It did help if I loosened the exhaust mainifold boltts some on the right side but you could get them off without doing that. BTW, that motor had allen head 1/4 inch bolts on the inside (manifold side) valve cover locations, lots of fun to get in and out until I made a extended allen head socket by welding a extension onto one of my allen head sockets Hopefully your going to use the M.W. size heads and intake and not the standard intake port sizes
[Re: Cab_Burge]
#478125
09/24/09 02:27 PM
09/24/09 02:27 PM
exhaust manifold on passenger side has to come off, the best part is the antifreeze leaking out of the water jacket bolt hole when you slide the manifold off.
[Re: Cab_Burge]
#478126
09/24/09 03:49 PM
09/24/09 03:49 PM
Posts: 176 Down under
slantman
Down under
Yes, I have a set of 518M heads and the MW size intake. I also have a set of 64 6-bolt valve covers. I am trying to keep the engine looking stock and original, so looks like I'll be loosening the exhaust manifold.
The plan at this stage is to put the MW top end on a 511 cube 11.0 to 1 comp short motor. I want to try and get around 530hp out of it, but keep the whole car looking stock, sort of like the FAST cars. It will see some street time, but I don't mind mixing race and pump gas. I was thinking of either using a custom street solid roller cam or a solid flat tappet cam. But I don't think the motor will see much past 6000rpm with the intake and exhaust manifolds, so maybe a solid flat tappet will suffice? Would it be easier on the valvetrain, especially with street miles and top end oiling?
[Re: slantman]
#478127
09/24/09 07:03 PM
09/24/09 07:03 PM
Posts: 7,506 Az
Crizila
Az
Never had to pull the intake manifold or loosen the exhaust manmifolds on my 63 to get the covers off. Did lots of valve adjusting with my trusty old P&G valve gaper. I would guess that something aint being repoped exactly as OEM if you gotta do that. As stated, the intake is a major pain to get on and off.
Fastest 300
[Re: HPMike]
#478129
09/24/09 08:40 PM
09/24/09 08:40 PM
slantman
Down under
Thanks for the info guys. Hey Mike, from your above post, I assume you're using Harland Sharp rockers? Do they fit under the stock valve covers okay? I was looking at either HS or RAS steel rockers. However, my 518 heads have been modified with the pushrod pinches removed, so I will need offset intake rockers. Not sure if RAS makes a suitable offset rocker, but I know HS do. We don't have a FAST racing class down here, but I want to build my car to look stock and run low 11's. This is my car.
[Re: slantman]
#478130
09/24/09 11:14 PM
09/24/09 11:14 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
Nice looking 63 Dodge. I use hedman 1-3/4 headers so I cant help you on that but I can admire your car. Ron
