Re: 11.5:1 comp with pump gas?
[Re: mopar dave]
#477676
09/23/09 04:28 PM
09/23/09 04:28 PM
Posts: 8,165 Left Coast
BobR
Left Coast
this has been talked about on here before, but my situation is alittle different. i will be pulling motor and trans soon for the 8" convertor install and thought it would be a good time to have the ports on the indys cleaned up better and shave the heads for more compression. i have a 408 with indy 360-1 heads with CP dish pistons that are ceramic coated on top and a solid roller cam 258/264@50-.650/.650 on a 108 and 45* of overlap. if i shave the heads .030" and use a .035" gasket this with give 11.5:1 compression, but do you think i will still be able to use pump gas? what would be the limit on pump gas with this combo? thanks
Detonation can be a silent killer. I wouldn't.
[Re: Big B]
#477681
09/23/09 05:17 PM
09/23/09 05:17 PM
Posts: 4,002 Joplin, Mo
rt66jim
Joplin, Mo
I've been running a 493/440 with 12.4:1 compresion for 4 years. Run the hell out of it. It's all about the cam. I have 266/271@.050 Here's the dyno sheet
What heads are on that motor?
[Re: rt66jim]
#477682
09/23/09 05:22 PM
09/23/09 05:22 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
IMO, I think you will be fine.
I have no quench at all (open chamber heads, .045 gasket, .005 out of the hole), compression comes out to 10.5. Cam is 259/259 duration at .050.
I ran it on pump 91 for a year and a half, without any known issues.
My cranking compression is only 145-150PSI.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Big B]
#477686
09/23/09 06:31 PM
09/23/09 06:31 PM
It has Indy-1's. Cranking psi is 195
if those are the actual #'s, you'll want a different cam. more static compression will just increase the cranking psi out of sight for pump gas.
#477687
09/23/09 06:52 PM
09/23/09 06:52 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
What gains are to be had on raising compression, only to pull timing out to compensate for too low a octane fuel rating? Yes it will run on pump gas after timing changes... IMO this combo will be counter productive, and wont be optimal.. ![](/ubbthreads/images/graemlins/Twocents.gif) I wouldnt bother with shaving the heads.. I would rather run optimal timing with a half point to a point less in compression, than run the compression up there and pull timing out, and fight detonation. Have you thought about E85 which is a pump fuel?
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: Big B]
#477688
09/23/09 07:01 PM
09/23/09 07:01 PM
Posts: 2,405 Wichita,KS
Blakcharger440
Wichita,KS
So what are the cam specs you are using to run 12.4:1 compression? ![](/ubbthreads/images/graemlins/shruggy.gif)
And are you referring to 91 or 93 at the pump? The best gas they sell around here is 91 or else you buy race gas.
[Re: mopar dave]
#477693
09/23/09 10:01 PM
09/23/09 10:01 PM
Posts: 5,746 Ontario, Canada
Dodgem
Ontario, Canada
ok, but what size should i be looking at? 268/274@50 on 108? this would be 10* more than i currently have. give me some ideas.
that would probably be the ticket but may need a 4800 stall or somewhere in between 264/270 ish??
[Re: Blakcharger440]
#477694
09/23/09 10:26 PM
09/23/09 10:26 PM
Posts: 325 Greenville, WI
Big B
Greenville, WI
I use 93 octane The cam is a Comp solid roller 266/271@50. 112 lobe sep 108 centerline .680 lift Pro-charger and fuel injection next ![](/ubbthreads/images/graemlins/thumbs.gif)
