11.5:1 comp with pump gas? #477675
09/23/09 03:48 PM
09/23/09 03:48 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
this has been talked about on here before, but my situation is alittle different. i will be pulling motor and trans soon for the 8" convertor install and thought it would be a good time to have the ports on the indys cleaned up better and shave the heads for more compression. i have a 408 with indy 360-1 heads with CP dish pistons that are ceramic coated on top and a solid roller cam 258/264@50-.650/.650 on a 108 and 45* of overlap.
if i shave the heads .030" and use a .035" gasket this with give 11.5:1 compression, but do you think i will still be able to use pump gas?
what would be the limit on pump gas with this combo? thanks
Re: 11.5:1 comp with pump gas? [Re: mopar dave] #477676
09/23/09 04:28 PM
09/23/09 04:28 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Detonation can be a silent killer. I wouldn't.
Re: 11.5:1 comp with pump gas? [Re: BobR] #477677
09/23/09 04:34 PM
09/23/09 04:34 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
My 416 has 72cc W2's Wiseco flattops with 5cc valve reliefs. Calculators figure it at 11.2. It will run on pump gas if you pull the timing back to 30*. It has 185 lbs of cranking compression. Jim
Re: 11.5:1 comp with pump gas? [Re: BobR] #477678
09/23/09 04:40 PM
09/23/09 04:40 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I run 11.6:1 on the street with pump gas in my hemi and have never had an issue. I run 50/50 race gas when at the track. There is a discussion thread about quench and cranking pressure that can tell you where the sweet spot is if you do a search. I keep a good eye on the tune-up just because of the compression I run, but I would rather have the horse power than not have it. The pistons were the same price either way.
Re: 11.5:1 comp with pump gas? [Re: rt66jim] #477679
09/23/09 04:43 PM
09/23/09 04:43 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
I think you are real close, eather way ya need to take cranking compression and find what #s you make with that cam, it seems 175-180psi is the upper limit, a lot depends on fuel type and quench, with 12 to 1 and a long duration cam we made 185 psi and ran pump 93 just moving the truck around the shop and yard , we went race fuel under load, same motor with a smaller roller 260@ .50 makes 220 psi so no 93 anymore
Re: 11.5:1 comp with pump gas? [Re: emarine01] #477680
09/23/09 04:50 PM
09/23/09 04:50 PM
Greenville, WI
Big B Offline
Big B  Offline
Greenville, WI
I've been running a 493/440 with 12.4:1 compresion for 4 years. Run the hell out of it. It's all about the cam. I have 266/271@.050
Here's the dyno sheet
Re: 11.5:1 comp with pump gas? [Re: Big B] #477681
09/23/09 05:17 PM
09/23/09 05:17 PM
Joplin, Mo
rt66jim Offline
rt66jim  Offline
Joplin, Mo
What heads are on that motor?
Re: 11.5:1 comp with pump gas? [Re: rt66jim] #477682
09/23/09 05:22 PM
09/23/09 05:22 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
IMO, I think you will be fine.
I have no quench at all (open chamber heads, .045 gasket, .005 out of the hole), compression comes out to 10.5. Cam is 259/259 duration at .050.
I ran it on pump 91 for a year and a half, without any known issues.
My cranking compression is only 145-150PSI.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: 11.5:1 comp with pump gas? [Re: Von] #477683
09/23/09 05:26 PM
09/23/09 05:26 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
A good test will be to go to the garage and warm up a bit pull all the plugs and the carb (I like to do it this way) and do a compression test to get an idea where you are cranking now??
Re: 11.5:1 comp with pump gas? [Re: rt66jim] #477684
09/23/09 06:15 PM
09/23/09 06:15 PM
Greenville, WI
Big B Offline
Big B  Offline
Greenville, WI
It has Indy-1's. Cranking psi is 195
Re: 11.5:1 comp with pump gas? [Re: Big B] #477685
09/23/09 06:28 PM
09/23/09 06:28 PM
Mt Morris Michigan
Mt Morris Michigan
heads are indy 360-1's with .039" quench, 10.75 comp and 190 cranking psi. been running pump gas with it for two seasons now without any problems and no black specks on plugs.
i figure that maybe with an aluminum head with .035" quench and coated piston tops i might get away with pump gas at 11.5 comp. dunno?
Re: 11.5:1 comp with pump gas? [Re: Big B] #477686
09/23/09 06:31 PM
09/23/09 06:31 PM
if those are the actual #'s, you'll want a different cam. more static compression will just increase the cranking psi out of sight for pump gas.
Re: 11.5:1 comp with pump gas? #477687
09/23/09 06:52 PM
09/23/09 06:52 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
What gains are to be had on raising compression, only to pull timing out to compensate for too low a octane fuel rating?
Yes it will run on pump gas after timing changes...
IMO this combo will be counter productive, and wont be optimal..
I wouldnt bother with shaving the heads..
I would rather run optimal timing with a half point to a point less in compression, than run the compression up there and pull timing out, and fight detonation.
Have you thought about E85 which is a pump fuel?
Re: 11.5:1 comp with pump gas? [Re: Big B] #477688
09/23/09 07:01 PM
09/23/09 07:01 PM
Wichita,KS
Blakcharger440 Offline
Wichita,KS
So what are the cam specs you are using to run 12.4:1 compression?
And are you referring to 91 or 93 at the pump? The best gas they sell around here is 91 or else you buy race gas.
Re: 11.5:1 comp with pump gas? [Re: Blakcharger440] #477689
09/23/09 07:11 PM
09/23/09 07:11 PM
Mt Morris Michigan
Mt Morris Michigan
i'm currently using sunoco ultra 93. what size cam would i have to step up to? how much overlap?
Re: 11.5:1 comp with pump gas? [Re: mopar dave] #477690
09/23/09 07:37 PM
09/23/09 07:37 PM
NC
440Jim Offline
440Jim  Offline
NC
Dave,
There are no guarantees. But if I was going to increase your CR, I would add more duration to the cam at the same time.
Re: 11.5:1 comp with pump gas? [Re: 440Jim] #477691
09/23/09 07:57 PM
09/23/09 07:57 PM
Mt Morris Michigan
Mt Morris Michigan
ok, but what size should i be looking at? 268/274@50 on 108? this would be 10* more than i currently have. give me some ideas.
Re: 11.5:1 comp with pump gas? [Re: mopar dave] #477692
09/23/09 08:58 PM
09/23/09 08:58 PM
Mt Morris Michigan
Mt Morris Michigan
i just figure while the engines out it will be a good opertunity to increase compression to get a few more ftlb of torque. if i cant do it with pump gas i'll just have to mix it.
Re: 11.5:1 comp with pump gas? [Re: mopar dave] #477693
09/23/09 10:01 PM
09/23/09 10:01 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
that would probably be the ticket but may need a 4800 stall
or somewhere in between 264/270 ish??
Re: 11.5:1 comp with pump gas? [Re: Blakcharger440] #477694
09/23/09 10:26 PM
09/23/09 10:26 PM
Greenville, WI
Big B Offline
Big B  Offline
Greenville, WI
I use 93 octane
The cam is a Comp solid roller
266/271@50. 112 lobe sep 108 centerline
.680 lift
Pro-charger and fuel injection next
