ABS pump runs continuously...HELP! #476717
09/22/09 04:20 PM
09/22/09 04:20 PM
Tulsa, Oklahoma
Wagonmaster Offline OP
Tulsa, Oklahoma
...2001 Dakota, 4 wheel drive, club cab, 318. ABS light and Brake light illuminated, as well.
Module? It seems the pump is working, or it would not be running. Hmmm....need a bit of input.
I tried this post in trucks...to no avail. Gotta get this one figured out...
Re: ABS pump runs continuously...HELP! [Re: Wagonmaster] #476718
09/22/09 04:24 PM
09/22/09 04:24 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
First get the codes pulled.You are just guessing till you do.Unplug the ABS fuse so the pump dosent burn up.Rocky
Chrysler Firepower
Re: ABS pump runs continuously...HELP! [Re: therocks] #476719
09/22/09 04:34 PM
09/22/09 04:34 PM
Tulsa, Oklahoma
Tulsa, Oklahoma
There is no code stored or current. I have unplugged the pump.
Re: ABS pump runs continuously...HELP! [Re: Wagonmaster] #476720
09/22/09 06:27 PM
09/22/09 06:27 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Stuck ABS pump relay... Saw dozens of them... Find the relay & tap on it.. If the pump stops you'll know why..
