Upper A-arm cam and bolts
#476425
09/22/09 08:50 AM
09/22/09 08:50 AM
Posts: 1,075 rochester,new york
plumebody
rochester,new york
I found mine were put in backwards and when I tried to adjust the alinement the bolts were just spinning and were found to be stripped. I would like to replace the cam and bolts. I have looked around but can't seem to locate. Any ideas? I checked BE/A,Jim's, no luck.
Re: Upper A-arm cam and bolts
[Re: mkdart]
#476427
09/22/09 09:04 AM
09/22/09 09:04 AM
Posts: 21,079 Niles , Ohio
therocks
Niles , Ohio
NAPA has them also.I believe even Advanced can get them.Rocky
Chrysler Firepower
[Re: plumebody]
#476432
09/22/09 11:18 PM
09/22/09 11:18 PM
Posts: 797 arizona, usa
lokalik
arizona, usa
not to highjack the post but. when using the moog offset bushings their instructions say to install one way however, there was a post on moparts saying to install oppsite of the moog instructions. can anyone explain way you would not follow the manufacture instructions for this?
[Re: lokalik]
#476433
09/23/09 09:21 AM
09/23/09 09:21 AM
therocks
Niles , Ohio
Follow the Moparts instructions.They are proper for Mopar.Moogs are for GM.Rocky
Chrysler Firepower
[Re: lokalik]
#476434
09/23/09 03:14 PM
09/23/09 03:14 PM
Posts: 553 DE
Ply72rr
DE
Because moog designed the offset bushings to cure a camber problem but we use them to gain positive caster.Installing them so the front moves the control arm out and the rear moves the arm in will increase pos caster.
