Re: Lets see some picks of your lowered Trucks
[Re: ramblebee]
#47474
11/12/07 12:37 AM
11/12/07 12:37 AM
Posts: 2,431 SK,Canada
gregsrt
SK,Canada
Here's my old 96, jut sold it in Sept. Belltech 2" and 4"
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry.
Thomas Jefferson
[Re: KatFysh]
#47485
11/12/07 07:52 PM
11/12/07 07:52 PM
Posts: 422 GSO.NC
Mstaedt
mopar addict
mopar addict
GSO.NC
Mstaedt, I remember seeing that thing driving around Jimmytown.. I'm glad you made it shorter and higher..
Yea, here's what it probably looked like when you saw it!
[Re: 83Ram4spd]
#47487
11/12/07 09:50 PM
11/12/07 09:50 PM
Posts: 6,048 Back home in PA
BulletBob
Back home in PA
The best way is to take a 2" long X 6"round piece of pipe & weld it to the spring pocket on the bottom of the lca. Take a torch or a plasma cutter & cut the pocket out from the inside. Weld 4 angle iron tabs to the bottom of the pipe & weld the piece that you cut with the torch inside the pipe. Use the pieces of angle to weld braces to.
Got pics?
How about this??
I'm going to build another set using the layout that I described. The 1st set I used too small of diameter pipe. I'll be building another set soon & will be perfecting the shortcomings of the 1st set. I'll take step by step pics when I build them. The 1st set worked but the spring would hang on the edge of the pocket & pop or make the truck sit uneven. I cut away & tried to make it stop but after it did stop there was no way to make it look good & some strength had been lost. I'm building something else too & I'll take pics of it too. Where's the mad scientist smiley?
[Re: 76dodgeboy]
#47489
11/16/07 12:43 AM
11/16/07 12:43 AM
Posts: 8,064 Iowa
76dodgeboy
Iowa
[Re: 76dodgeboy]
#47490
11/16/07 02:12 PM
11/16/07 02:12 PM
before: after: I own this too, but it's in a lot of pieces now.
[Re: 76dodgeboy]
#47491
11/16/07 04:04 PM
11/16/07 04:04 PM
Posts: 2,109 Byron, NY
W.I.N. Racing
Byron, NY
Here's the replacment for that one
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: 76dodgeboy]
#47492
11/16/07 04:06 PM
11/16/07 04:06 PM
W.I.N. Racing
Byron, NY
