Page 4 of 5 1 2 3 4 5
Re: Lets see some picks of your lowered Trucks [Re: RedRam] #47473
11/12/07 12:27 AM
11/12/07 12:27 AM
Amarillo, Tx
ramblebee Offline
ramblebee  Offline
Amarillo, Tx
On thier website they say 74-93.Why would they not fit a 73 model?
Re: Lets see some picks of your lowered Trucks [Re: ramblebee] #47474
11/12/07 12:37 AM
11/12/07 12:37 AM
SK,Canada
gregsrt Offline
gregsrt  Offline
SK,Canada
Here's my old 96, jut sold it in Sept. Belltech 2" and 4"
An association of men who will not quarrel with one another is a thing which has never yet existed, from the greatest confederacy of nations down to a town meeting or a vestry. Thomas Jefferson
Re: Lets see some picks of your lowered Trucks [Re: gregsrt] #47475
11/12/07 01:01 AM
11/12/07 01:01 AM
Colo Springs, CO
DconD100 Offline
DconD100  Offline
Colo Springs, CO
Flip the rear, removed a leaf from the front. Had to modify the oil pan and the driver's side header.
Pump Gas Small Blocks Rock! 11.53 @ 116mph E85 408 at 8500 ft da, 3605 pound truck, 3.91s, street driven
Re: Lets see some picks of your lowered Trucks [Re: RedRam] #47476
11/12/07 01:59 AM
11/12/07 01:59 AM
Sunnyvale, CA.
3XCHARM Offline
3XCHARM  Offline
Sunnyvale, CA.
bouchillon sells lower control arms now.
http://www.bouchillonperformance.com/BPE37493DropKit.asp
Those arms from bouchillon look VERY simular to the arms I got from Chisholm in 97.
I'll post a pic asap, camera batt is dead.
That is the same exact design that AIM sells except the ones I got were blue. AIM also sells adjustable upper control arms as well.
1975 Ramcharger 6" lift 35" Mud Terrains 8 lug 44 front, 60 rear. (R.I.P.)
1976 D100 lowered 3" & 5" Now with a 440!!! (sold)
On the hunt for another beauty to build.
Re: Lets see some picks of your lowered Trucks [Re: 3XCHARM] #47477
11/12/07 04:33 AM
11/12/07 04:33 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
AIM ??????
I am truckless..
Re: Lets see some picks of your lowered Trucks [Re: 340SHORTY] #47478
11/12/07 07:18 AM
11/12/07 07:18 AM
Appalachia
RedRam Offline
RedRam  Offline
Appalachia
AIM ??????
click here http://www.truckin.com/
Re: Lets see some picks of your lowered Trucks [Re: 76dodgeboy] #47479
11/12/07 10:35 AM
11/12/07 10:35 AM
GSO.NC
Mstaedt Offline
mopar addict
Mstaedt  Offline
mopar addict
GSO.NC
came this way from the factory. I lifted and shortened it
Re: Lets see some picks of your lowered Trucks [Re: Mstaedt] #47480
11/12/07 10:48 AM
11/12/07 10:48 AM
scratchnfotraction Offline
6 doors and 6 wheels now thats big pimpin
-mike
Re: Lets see some picks of your lowered Trucks [Re: RedRam] #47481
11/12/07 11:53 AM
11/12/07 11:53 AM
British Columbia
chrisf Offline
chrisf  Offline
British Columbia
AIM ??????
thats the LAST company on earth i would deal with. i would send frank mitchel a blank cheque first
Re: Lets see some picks of your lowered Trucks [Re: ramblebee] #47482
11/12/07 12:08 PM
11/12/07 12:08 PM
Iowa
76dodgeboy Offline OP
Iowa
You cut 2 full coils and no alignment troubles? Im getting ready to cut the coils on my extended cab and need to know how much cut is possible with out alignment probs. Thanks Harry.
Re: Lets see some picks of your lowered Trucks [Re: Mstaedt] #47483
11/12/07 06:17 PM
11/12/07 06:17 PM
Falconer, NY
KatFysh Offline
KatFysh  Offline
Falconer, NY
Mstaedt, I remember seeing that thing driving around Jimmytown.. I'm glad you made it shorter and higher..
When you decide to quit, THAT is the moment when you would've succeeded..
Re: Lets see some picks of your lowered Trucks [Re: 76dodgeboy] #47484
11/12/07 06:20 PM
11/12/07 06:20 PM
Amarillo, Tx
ramblebee Offline
ramblebee  Offline
Amarillo, Tx
I had to move the lower control arm mounting points in so it would align.It rides pretty good but im not comfortable with cutting that much of the springs.So im going to try the bouchillon arms.I have a fresh set of coils to install. Ill take one round out and see what happens.I want the front suspension to be solid on this truck because Id like to daylight the front tires on launch when its finished.
Re: Lets see some picks of your lowered Trucks [Re: KatFysh] #47485
11/12/07 07:52 PM
11/12/07 07:52 PM
GSO.NC
Mstaedt Offline
mopar addict
Mstaedt  Offline
mopar addict
GSO.NC
Yea, here's what it probably looked like when you saw it!
Re: Lets see some picks of your lowered Trucks [Re: 76dodgeboy] #47486
11/12/07 09:04 PM
11/12/07 09:04 PM
Georgia
CopperDodge Offline
CopperDodge  Offline
Georgia
Western Chassis 2/4 drop with 1/2 coil cut from the front end.
Re: Lets see some picks of your lowered Trucks [Re: 83Ram4spd] #47487
11/12/07 09:50 PM
11/12/07 09:50 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
The best way is to take a 2" long X 6"round piece of pipe & weld it to the spring pocket on the bottom of the lca. Take a torch or a plasma cutter & cut the pocket out from the inside. Weld 4 angle iron tabs to the bottom of the pipe & weld the piece that you cut with the torch inside the pipe. Use the pieces of angle to weld braces to.
Got pics?
How about this??
I'm going to build another set using the layout that I described. The 1st set I used too small of diameter pipe. I'll be building another set soon & will be perfecting the shortcomings of the 1st set. I'll take step by step pics when I build them. The 1st set worked but the spring would hang on the edge of the pocket & pop or make the truck sit uneven. I cut away & tried to make it stop but after it did stop there was no way to make it look good & some strength had been lost. I'm building something else too & I'll take pics of it too. Where's the mad scientist smiley?
Re: Lets see some picks of your lowered Trucks [Re: Mstaedt] #47488
11/12/07 10:22 PM
11/12/07 10:22 PM
NW Pa
DARTROD Offline
DARTROD  Offline
NW Pa
Mark,
Your truck looks great now,but i want one from that Factory. I'd just have to buy another house,i don't think it would go over my curb and down the driveway.
I've been trying to figure out how low my 95 extended cab could go without scraping.2 full coils i think would be too much,on an ext cab,atleast in my drive.
PROUD member of The Patriot Guard Riders
Re: Lets see some picks of your lowered Trucks [Re: 76dodgeboy] #47489
11/16/07 12:43 AM
11/16/07 12:43 AM
Iowa
Iowa
Now this is low
Re: Lets see some picks of your lowered Trucks [Re: 76dodgeboy] #47490
11/16/07 02:12 PM
11/16/07 02:12 PM
before:
after:
I own this too, but it's in a lot of pieces now.
Re: Lets see some picks of your lowered Trucks [Re: 76dodgeboy] #47491
11/16/07 04:04 PM
11/16/07 04:04 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Here's the replacment for that one
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Lets see some picks of your lowered Trucks [Re: 76dodgeboy] #47492
11/16/07 04:06 PM
11/16/07 04:06 PM
Byron, NY
Byron, NY
Now this is low
'60 Willys CJ5
