Page 2 of 5 1 2 3 4 5
Re: Lets see some picks of your lowered Trucks [Re: onebadstepside] #47433
11/10/07 04:04 PM
11/10/07 04:04 PM
Friendly, WV
wedgeheaded Offline
wedgeheaded  Offline
Friendly, WV
2in lower control arms and ladderbars and coilovers
Your truck is a class act.
Re: Lets see some picks of your lowered Trucks [Re: wedgeheaded] #47434
11/10/07 06:59 PM
11/10/07 06:59 PM
Parsons (SouthEast) Kansas
funkyjbp Offline
mopar addict
funkyjbp  Offline
mopar addict
Chisholm does not make the LCAs anymore and won't, believe me, i've tried to talk them into it. search the board for "lowered or dropped" terms i nthe truck forum only. lots of stuff already discussed. I just posted and plan to add dak dropped spindles to my Chisholm two inch dropped springs. later, JP in Kansas.
71 SWB, 413 77 SWB, 318 92 SWB, 5.2 magnum 79 Macho Short bed, 318 03 stratus coupe R/T too many others not on the road!
Re: Lets see some picks of your lowered Trucks [Re: 76dodgeboy] #47435
11/10/07 07:08 PM
11/10/07 07:08 PM
The Thumb O' Michigan
Fluffy Offline
Automotive STD Guy
Fluffy  Offline
Automotive STD Guy
Engine Swap and Blocks.
Re: Lets see some picks of your lowered Trucks [Re: Fluffy] #47436
11/10/07 08:11 PM
11/10/07 08:11 PM
S.L . MI
clutch Offline
clutch  Offline
S.L . MI
Re: Lets see some picks of your lowered Trucks [Re: clutch] #47437
11/10/07 08:29 PM
11/10/07 08:29 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
The best way is to take a 2" long X 6"round piece of pipe & weld it to the spring pocket on the bottom of the lca. Take a torch or a plasma cutter & cut the pocket out from the inside. Weld 4 angle iron tabs to the bottom of the pipe & weld the piece that you cut with the torch inside the pipe. Use the pieces of angle to weld braces to.
Re: Lets see some picks of your lowered Trucks [Re: 76dodgeboy] #47438
11/10/07 08:39 PM
11/10/07 08:39 PM
East of nowhere
41hemi Offline
Wife thinks I am Crazy!
41hemi  Offline
East of nowhere
How much did you take out of the coils? 1.5?
Yes 1.5
Re: Lets see some picks of your lowered Trucks [Re: BulletBob] #47439
11/10/07 09:48 PM
11/10/07 09:48 PM
Piqua, Ohio
dodgeram440 Offline
dodgeram440  Offline
Piqua, Ohio
Got pics?
Re: Lets see some picks of your lowered Trucks [Re: dodgeram440] #47440
11/10/07 10:55 PM
11/10/07 10:55 PM
Sarcoxie, MO, USA
MoPar Jamie Offline
MoPar Jamie  Offline
Sarcoxie, MO, USA
Heres my old '73 that I sold 400-4 up front with one coil cut off the front springs, longer shackles in the rear with only 4 leafs in the springs. 15x8 Li'l red wheels with 235/75/15 rubber. I want my '88 to be that low when I'm done.
- MoPar Jamie
1972 Fury III 4dr
1986 D-150 LWB Royal SE
Re: Lets see some picks of your lowered Trucks [Re: MoPar Jamie] #47441
11/10/07 10:57 PM
11/10/07 10:57 PM
Sarcoxie, MO, USA
MoPar Jamie Offline
MoPar Jamie  Offline
Sarcoxie, MO, USA
Heres my '88 as it sits. I've added a bumper up front and the bigger mirrors that were optional that year. Otherwise its the same.
- MoPar Jamie
1972 Fury III 4dr
Re: Lets see some picks of your lowered Trucks [Re: MoPar Jamie] #47442
11/10/07 11:09 PM
11/10/07 11:09 PM
Alberta, Canada
K
ktbundy Offline
super gas
ktbundy  Offline
super gas
K
Alberta, Canada
Mustang II front end and an Alston 4 link rear. Not the cheapest way to lower a truck, but it works well.
Re: Lets see some picks of your lowered Trucks [Re: dodgeram440] #47443
11/10/07 11:19 PM
11/10/07 11:19 PM
Beebe, AR
83Ram4spd Offline
83Ram4spd  Offline
Beebe, AR
Got pics?
How about this??
Speed kills.......Drive a Ford and live forever!!!!
Re: Lets see some picks of your lowered Trucks [Re: 83Ram4spd] #47444
11/11/07 12:04 AM
11/11/07 12:04 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Any of you guys with the 2" drop lower control arms, can you post a picture of the chisholm arm?
I just got a truck, and its reported to have the 2" drop arms on it, but they look pretty normal to me.
Are there any identifying characteristics, like the pocketed arms?
Re: Lets see some picks of your lowered Trucks [Re: 83Ram4spd] #47445
11/11/07 12:38 AM
11/11/07 12:38 AM
Ontario Canada
Webster Offline
Webster  Offline
Ontario Canada
Got pics?
How about this??
Nice job! I bet you could sell afew of those
Re: Lets see some picks of your lowered Trucks [Re: Webster] #47446
11/11/07 12:40 AM
11/11/07 12:40 AM
Nice trucks!
Re: Lets see some picks of your lowered Trucks [Re: 83Ram4spd] #47447
11/11/07 01:18 AM
11/11/07 01:18 AM
Piqua, Ohio
dodgeram440 Offline
dodgeram440  Offline
Piqua, Ohio
Got pics?
How about this??
That is sweet! Reminds me of an episode of Musclecar on Spike Tv. Lou did that with a Pontiac Tempest lca. What did you use for the steel and where did you get it?
Re: Lets see some picks of your lowered Trucks [Re: 76dodgeboy] #47448
11/11/07 01:47 AM
11/11/07 01:47 AM
Gloucester,VA STOP MOVING HERE
RangerDan440 Offline
this was at Carlisle. And its sexy
Re: Lets see some picks of your lowered Trucks [Re: 83Ram4spd] #47449
11/11/07 07:56 AM
11/11/07 07:56 AM
Friendly, WV
wedgeheaded Offline
wedgeheaded  Offline
Friendly, WV
Got pics?
How about this??
I was thinking this might work and that's about what I imagined. You do nice work, it looks neat.
Re: Lets see some picks of your lowered Trucks [Re: wedgeheaded] #47450
11/11/07 10:37 AM
11/11/07 10:37 AM
S.L . MI
clutch Offline
clutch  Offline
S.L . MI
My lowering method was done the hard way . Van lower control arms, 5th avenue spindles lower contol arm mounts moved in 3/4" for alignment purposes ,trick GM F-body springs, Strange adjustable B-body shocks. , Rear end flopped different spring hangers and shackles , shock brackets relocated on coilover brackets
Re: Lets see some picks of your lowered Trucks [Re: clutch] #47451
11/11/07 11:45 AM
11/11/07 11:45 AM
S.E. South Dakota !
bigdad Online content
Still Posting A Lot
bigdad  Online Content
Still Posting A Lot
S.E. South Dakota !
Mine
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Lets see some picks of your lowered Trucks [Re: bigdad] #47452
11/11/07 12:16 PM
11/11/07 12:16 PM
Ontario Canada
Webster Offline
Webster  Offline
Ontario Canada
Mine
I Can't help it!!
